I purchased it on eBay from a private seller who upgraded to an RNS510.
I thought it was legit when I saw the VW box and original VW manual.
Everything seems to operate as advertised - just button layout is different.
(The seller was a VW tech who installed it for me in < 10 minutes)
PS Still hanging out for intelligence as to how to display time of day on the RCD510
I have seen this discussion...
http://forums.vwvortex.com/zerothread?id=4811536
...which discusses (amongst other subjects) setting the clock on the RCD510 and shows pictures of the unit displaying the time.
Try asking in the Audio section http://www.vwwatercooled.org.au/foru...nd-Electronics
Any idea what the part number is for this?
I've found one on the bay with 5KO 035 190. Just want to make sure this is the right one.
Apparently it is possible e.g. VWvortex Forums: RNS-510 Install: MkV R32
and for the Mk6 some info http://forums.vwvortex.com/zerothread?id=4748187
just a quick question, does the sat nav work when you replace it?
