Good luck sman66. Hope you get it sorted. Maybe find yourself a cancelled order that suits you and is on its way. Apparently, non-metro dealers may have orders not sold yet.
As to long waits for R's, common wisdom around here is demand > planned supply. Constraint in supply of some parts has been suggested as the culprit. Similar situation is happening to new model Polo.
If you are sticking with your factory order, build date is key in figuring out ETA. Once past that bottleneck, the other things that needs to happen can flow smoothly.
2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
I went to the dealership today and found out that the broker had only passed on the order to them a month after I paid my deposit...so the 23rd october 2011.
The dealer showed me the screen that said final assemby 22/3 at the bottom it had arrive Australia 27/5. The dealer told me I would definitely have it within about 10 days of this date.
He also told me any orders made now on golf R's or polo GTi's were being quoted a 12 month wait...it seems that demand is far outstripped by
supply despite the factory having a 23hour day.
So lessons learnt are : NEVER use a broker again and Patience is a virtue grrrrrrr!
If you are sticking with your factory order, build date is key in figuring out ETA. Once past that bottleneck, the other things that needs to happen can flow smoothly.[/QUOTE]
So i just got my NADCON screenshot for the ETA data and i have a few questions.
I understand that the dates listed per line can and very well may vary. For those of you that have taken delivery of their cars, how accurate are those dates?
On the first page of this thread it says
"A VIN number will only be allocated when the car is handed to production. It should be available to your detail at "Checkpoint 8" which is Step 15 of the list below."
If my NADCON screenshot says that checkpoint 8 handover was on 16/2/11 does that mean i should already have a VIN assigned? If so is the VIN displayed on the NADCON screenshot because i don't see it anywhere.
"Arrival at final destination" would I be correct in assuming that is the port that it arrives at in Australia?
ETA means ESTIMATED Time of Arrival. So really, that should answer the question for you. They're estimates. Rough guides. How "accurate" will vary on many things. No point really going any further than that.
NADCON is an application. There are many screens. It would be on the Order > Order Details > Car Configurator screen.
Basically.
The VIN number is straight under the Checkpoint Date on the NADCON Extended Information Screen and is labelled Chassis Number and if you have a Checkpoint 8 Date you should have the Chassis number. My Checkpoint Date was 8/2/2011 and my GTI is now sitting on the docks at Bremerhaven hopefully hitching a ride on Torino which is in port loading at the moment.
Mark 7.5 2018 White Golf R with Driver Assist & Dynaudio packages.
Polo 77TSI White Comfortline DSG - partner drives
We are a VW family
I was only provided screenshots of the "order - ETA data" and "order - Order details" screens.
You're best to ask the dealer for what I said above. There is no "Extended Information" Screen - that is simply a table towards the bottom of the "Order > Order Details > Car Configurator" as I mentioned in my post above!
See my quote above. If you've already been given some info from the "Order Details" screen, make sure your dealer then goes to the "Car Configurator" screen (if it's not already there) and then scroll down to almost the bottom. The "Extended Information" table is the 2nd bottom table.
The Queen Sapphire is almost here!
might even be 2 days early by the looks of it:
BREMERHAVEN GERMANY 31/01/2011 02/02/2011
ZEEBRUGGE BELGIUM 02/02/2011 03/02/2011
SOUTHAMPTON UNITED KINGDOM 04/02/2011 04/02/2011
PORT ELIZABETH SOUTH AFRICA 19/02/2011 19/02/2011
DURBAN SOUTH AFRICA 21/02/2011 21/02/2011
FREMANTLE AUSTRALIA 03/03/2011 03/03/2011
MELBOURNE AUSTRALIA 08/03/2011 08/03/2011
PORT KEMBLA AUSTRALIA 10/03/2011 10/03/2011
BRISBANE AUSTRALIA 12/03/2011 12/03/2011
