Results 11 to 20 of 23
Thread: How to reset/apply Basic Settings for the 7 Speed DSG?
    Siberia.Omsk
    I'd like to share procedure "How to perform basic settings to gearbox DSG 7".
    Please take a look at my article on Russia Yeti club.
    I'm sorry, it’s on Russian (in original), but I tried to translate it via Google for you:
    I hope this information will be helpful.
    Feb 2009
    Sydney, Australia
    Thanks UKV
    Welcome to the forums.
    Quote Originally Posted by UKV View Post
    Dude that's awesome! I will try it out as soon as possible. But just to make sure I understood the Russian translation:
    1)Handbrake On, Car is in Park and Ignition is on but Engine is off. (Transmission should be warmed up already before doing this)
    2)Go to 02 - Electronics & Measurement Group / Basic Settings > Group 60 > Read
    3)Wait for fields to display the following information: 4 - 0 - 0 and then turn on Ignition within 10 seconds. (or it will display 255 - 7 - 0 and this means you'll have to start over again)
    4)After a few seconds the fields will now display 254 - 0 - 0 which should mean that the process is complete. (Handbrake should be enough to hold car in position, but just to be safe you should fully depress brakes too)
    5)Exit VAGCOM and turn off engine; Basic settings are now complete.
    That's all, right?
    Siberia.Omsk
    Quote Originally Posted by Digitalic View Post
    That's all, right?
    Some correction for 3) and 4).
    3) the "... and then turn on Ignition within 10 seconds" must be replaced with "... and then start engine in next 10 seconds".
    4) the "... but just to be safe you should fully depress brakes too" is not need to perform.
    So, full correct version is:
    3)Wait for fields to display the following information: 4 - 0 - 0 and then start engine in next 10 seconds. (or it will display 255 - 7 - 0 and this means you'll have to start over again)
    4)After a few seconds the fields will now display 254 - 0 - 0 which should mean that the process is complete. (Handbrake will be enough to hold car in position)
    ---------- Post added at 10:40 PM ---------- Previous post was at 09:47 PM ----------
    In additional, you may to perform (as optional):
    Test drive after DSG 0AM basic settings
    If the tester is held on the passenger seat or operated from there during the test drive, this
    can lead to serious injuries during an accident, if the passenger airbag goes off.
    Please take good care of the traffic. Do not endanger the traffic in any way.
    Test drive:
    1. Pulling away from stationary.
    - Pull away twice forwards in driving mode D up to 2nd gear gear.
    - Pull away twice backwards.
    2. Drive in every gear also in reverse gear.
    - Gear lever in tip gate.
    - Drive in every gear for at least 3 seconds.
    3. Drive alternately in 3rd, 5th or 7th gear and in 4th or 6th gear.
    - Rev range 2000 - 4500 rpm.
    - one minute in the 3. 5th or 7th gear and one minute in 4th or 6th gear
    - Repeat twice.
    Drive with different accelerator pedal positions. The control unit must recognise for a short
    moment the value for full acceleration. It is not necessary to reach the top speed.
    4. Finally, check the shifting of the gearbox.
    - Drive in every gear in driving mode D, also in reverse gear.
    - If negative repeat point 3.
    Note:
    Check adaptations in measured value blocks 180_1 and 200_1. (my note: may be not the same numbers in your case, since numbers block it's depend on software version of DSG 7)
    The number should be at least 3 per clutch.
    If the test drive cannot be performed in the recommended way or for necessary length, the
    still open fast adaptations are automatically and unnoticeably performed in the subsequent
    driving cycles.
    Jun 2011
    Can you guys tell me which one of these is the software version and what the latest software version is, I think my dealership are just resetting it and not actually updating anything.
    Hi Mate,
    TPI 2021116/4 is the Technical Product Information for the revised software. Makes the car much more drivable.
    MY09 118TSI - SOLD
    Siberia.Omsk
    I'm glad to share with all owners of DSG 7 who wants to perform basic setting and initial learning in DSG 7
    this original procedure:
    Technical product information
    Transaction No.: 2025490/1
    3511, 1P, 5P, 6J, Basic setting and initial learning in DSG (0AM - 7sp.) gearboxes
    Release date: 12-Apr-2011
    Customer statement / workshop findings
    The basic setting in DSG (0AM – 7sp.) gearboxes cannot be performed with guided fault finding.
    Technical background
    Various causes have been detected, including the main reason of low battery voltage.
    On completion of the basic settings, the handling of the transmission does not improve.
    Production change
    Measure
    ATTENTION!
    - Connect a battery charger to ensure the power supply of the vehicle.
    - Check that the diagnostic connector is correctly plugged in.
    - Update the VAS 505X to the most recent version available.
    - The transmission must have an ATF temperature of more than 60° C.
    Proceed as follows to perform the basic setting:
    1.- Vehicle at standstill
    2.- Engine switched off
    3.- Gear lever in Parking position
    4.- Handbrake on
    5.- Brake pedal depressed
    With the VAS 505X connected and the ignition on (Current 15):
    1.- Enter Self-diagnosis
    2.- Select Transmission
    3.- Basic settings
    4.- Enter value block 60 and Q
    The following reference values are displayed:
    253 1 12: The basic setting has commenced
    4 0 0: Start the engine
    254 0 0: The basic setting has been successfully completed
    255 0 0: The basic setting was interrupted
    If value 254 is displayed, this indicates that the basic setting has ended successfully, then
    switch off the ignition and remove the key, 3 seconds.
    ATTENTION!
    When test driving the vehicle, traffic conditions must be observed.
    Start the vehicle and test drive vehicle for the initial learning of the DSG (0AM – 7sp.) gearbox.
    Test drive:
    1-Place the gear lever in position D and perform two driving cycles
    forwards from 0 km/h to 2nd gear.
    Place the gear lever in position R and perform two driving cycles in
    reverse (drive for a few metres).
    2-Place the gear lever in Tiptronic.
    Drive in all gears including reverse gear (R).
    Drive in each gear for at least 3 seconds.
    3-Place the gear lever in Tiptronic.
    Alternate between an odd number gear (3 or 5 or 7) and an even number gear
    (4 or 6).
    Keep the engine speed between 2000 and 4500 rpm for approximately 5
    minutes in each odd and even number gear.
    Repeat twice.
    Continue test driving with different acceleration percentages.
    The Mechatronics control unit must give the maximum acceleration values for a moment.
    The vehicle maximum speed must not be reached.
    4-Lastly, test drive the vehicle with the customer and confirm the improvements in the
    DSG (0AM – 7sp.) gearbox gears.
    Drive in D (Drive) and R (Reverse).
    If the gears jerk or are harsh, repeat step 3.
    Check value blocks 180-1 and 200-1. The number should be at least 3
    for each clutch adaptation.
    It is not possible to recommend the class and form or the required length.
    An unjustified repair or replacement of the part may lead to the refusal of the warranty claim.
    Warranty accounting instructions
    TA no. / Anomaly / Manufacturer: 3511 / 0040 / …
    No. of work position Description of work position Time Units (TU)
    01 50 00 00 Guided fault finding/guided function According to diagnosis log. 1)
    1) The times indicated are only applicable to this TPI. When submitting the warranty application, please include the number of the TPI used to streamline the process.
    Parts information
    When necessary, consult the genuine parts catalogue to obtain the part in its most updated form.
    Apr 2010
    I tried a clutch adaption reset technique in the Basic Settings (block 200) to try to fix a problem, which didn't help, so I tried this out tonight. I didn't receive the expected output though:
    Do I assume that the 255 means it failed? Any idea what 93 means, and where to go from here?
    After waiting for about 2 minutes (in case the numbers would change again) I closed VCDS and decided to test the car out, put it in reverse, and slowly left my parking space - was nice and smooth, just as I went to apply some more power, I hear the car rev as in neutral. Try driving forwards again, same thing. See a car coming towards me. Commence panicking.
    Try turning the car off and back on again, and everything works fine. Notice the instruction at the end that says to turn the car off when completed (thought I did that but can't remember) - anyway sigh of relief.
    The car did drive smoother than before but I didn't get a chance to completely test if the original problem was fixed (car revs up and down inbetween 2700-3000rpm when applying moderate power in gears 4 and 6).
    Thanks for the instructions, if you have any other comments please let me know.
    Siberia.Omsk
    Ryan_R,
    I'm so sorry, but only now have to see your post.
    255 in first field means error that was occurred during process of Basic Settings for DSG-7(0AM).
    Second field is specific error code, your have 93. This is “Neutral Switch n_An timeout”.
    Let me share for all full error list (specific error codes) that maybe shown if you have 255 in first field.
    This list on German language (in original), but may be easy translated by Google, for example.
    0 0 kein Abbruch
    1 1 Abbruch durch User
    2 2 Keine Grd-Teilvorgabe (2)
    3 3 Voraussetzungen Timeout (3)
    4 4 Neutralschalten wenig Speicherdruck (4)
    5 5 Systemvorbereitung n_An Timeout (5)
    6 6 Neutralschalten GS13 Timeout (6)
    7 7 Warte auf Motorstart Timeout (7)
    8 8 Systemvorbereitung p_Speicher Timeout (8)
    9 9 Wellenkontrolle W1 Timeout (9)
    10 10 Kupplung Nulllage K2 nicht stabil (10)
    11 11 Kupplung Nulllage K1 nicht stabil (11)
    12 12 Vorbereitung Eingelegt p_Speicher Timeout (12)
    13 13 Eingelegtpos Gangeinl G1 unplausibel Timeout (13)
    14 14 Eingelegtpos Neutralsch GS13 Timeout (14)
    15 15 Vorbereitung Sync-Punkt GS13 stabil Timeout (15)
    16 16 Vorbereitung Sync-Punkt n_An Timeout (16)
    17 17 Kupplungswegrampe1 Schleifpunkt Timeout (17)
    18 18 Kupplungswegrampe2 Offset Timeout (18)
    19 19 Kupplungswegrampe3 x-Nm G1 Timeout (19)
    20 20 Kupplungswegrampe4 Kup_auf Timeout (20)
    21 21 Kupplungswegrampe5 ZuPunkt_K1 Timeout (21)
    22 22 Kupplungswegrampe6 Kup_auf Timeout (22)
    23 23 Kupplungswegrampe7 Kup_auf Timeout (23)
    24 24 Kupplungswegrampe8 Timeout (24)
    25 25 Kupplungswegrampe9 Timeout (25)
    26 26 Kupplungswegrampe10 Kup_auf Timeout (26)
    27 27 Gangeinleg_Synchronpos. G1 Timeout (27)
    28 28 Neutralpos. nach x_NM GS13 Timeout (28)
    29 29 Druckrampe2 WDK Timeout (29)
    30 30 Pruefe Druckrampe2 WDK Timeout (30)
    31 31 Druckrampe4 WDK Timeout (31)
    32 32 Druckrampe3 WDK Werteableg1 Timeout (32)
    33 33 Druckrampe5 WDK Werteableg2 Timeout (33)
    34 34 WegDruck Kennl. NEw oder KupZu stabil Timeout (34)
    35 35 Druckrampe6_Kupwegrampe8 Kup_auf Timeout (35)
    36 36 Kennwerte Ablegen Timeout (36)
    37 37 Druckstuetzstelle unplausibel (37)
    38 38 Kupwegrampe11 Kup_auf Timeout (38)
    39 39 Kupwegrampe12 Kup_auf Timeout (39)
    40 40 Neutralschalten GS24 Timeout (40)
    41 41 Neutralschalten GS57 Timeout (41)
    42 42 Neutralschalten GS6R Timeout (42)
    43 43 Neutralschalten K1 Timeout (43)
    44 44 Neutralschalten K2 Timeout (44)
    45 45 Wellenkontrolle W2 Timeout (45)
    46 46 Wellenkontrolle K1 Timeout (46)
    47 47 Wellenkontrolle K2 Timeout (47)
    48 48 Vorbereitung Eingelegt K1 Timeout (48)
    49 49 Vorbereitung Eingelegt K2 Timeout (49)
    50 50 Vorbereitung Eingelegt GS13 Timeout (50)
    51 51 Vorbereitung Eingelegt GS24 Timeout (51)
    52 52 Vorbereitung Eingelegt GS57 Timeout (52)
    53 53 Vorbereitung Eingelegt GS6R Timeout (53)
    54 54 Eingelegtpos Gangeinl G2 unlpausibel Timeout (54)
    55 55 Eingelegtpos Gangeinl G3 unplausibel Timeout (55)
    56 56 Eingelegtpos Gangeinl G4 unplausibel Timeout (56)
    57 57 Eingelegtpos Gangeinl G5 unplausibel Timeout (57)
    58 58 Eingelegtpos Gangeinl G6 unplausibel Timeout (58)
    59 59 Eingelegtpos Gangeinl G7 unplausibel Timeout (57)
    60 60 Eingelegtpos Gangeinl GR unplausibel Timeout (60)
    61 61 Eingelegtpos Neutralsch GS24 Timeout (61)
    62 62 Eingelegtpos Neutralsch GS57 Timeout (62)
    63 63 Eingelegtpos Neutralsch GS6R Timeout (63)
    64 64 Vorbereitung Sync-Punkt GS24 stabil Timeout (64)
    65 65 Vorbereitung Sync-Punkt GS65 stabil Timeout (65)
    66 66 Vorbereitung Sync-Punkt GS66 stabil Timeout (66)
    67 67 Vorbereitung Sync-Punkt W1 stabil Timeout (67)
    68 68 Kupplungswegrampe3 x-Nm G2 Timeout (68)
    69 69 Kupplungswegrampe3 x-Nm G3 Timeout (69)
    70 70 Kupplungswegrampe3 x-Nm G4 Timeout (70)
    71 71 Kupplungswegrampe3 x-Nm G5 Timeout (71)
    72 72 Kupplungswegrampe3 x-Nm G6 Timeout (72)
    73 73 Kupplungswegrampe3 x-Nm G7 Timeout (73)
    74 74 Kupplungswegrampe3 x-Nm GR Timeout (74)
    75 75 Kupplungswegrampe5 ZuPunkt_K2 Timeout (75)
    83 83 Gangeinleg_Synchronpos. G2 Timeout (83)
    84 84 Gangeinleg_Synchronpos. G3 Timeout (84)
    85 85 Gangeinleg_Synchronpos. G4 Timeout (85)
    86 86 Gangeinleg_Synchronpos. G5 Timeout (86)
    87 87 Gangeinleg_Synchronpos. G6 Timeout (87)
    88 88 Gangeinleg_Synchronpos. G7 Timeout (88)
    89 89 Gangeinleg_Synchronpos. GR Timeout (89)
    90 90 Neutralpos. nach x_NM GS24 Timeout (90)
    91 91 Neutralpos. nach x_NM GS57 Timeout (91)
    92 92 Neutralpos. nach x_NM GS6R Timeout (93)
    93 93 Neutralschalten n_An Timeout (93)
    94 94 Vorbereitung Sync-Punkt W2 stabil Timeout (94)
    100 100 Kupwegrampe 14 Kup_zu K1 Timeout
    101 101 Kupwegrampe 14 Kup_zu K2 Timeout
    102 102 Kupwegrampe 15 Kup_auf K1 Timeout
    103 103 Kupwegrampe 15 Kup_auf K2 Timeout
    128 128 Vorausetzung Fehler: Temperatur
    256 256 Vorausetzung Fehler: Waehlhebel nicht in P
    512 512 Vorausetzung Fehler: Fzg-Geschw. nicht NULL
    1024 1024 Vorausetzung Fehler: TG1/2 ausgefallen
    2048 2048 Vorausetzung Fehler: Batteriespannung niedrig
    4096 4096 Vorausetzung Fehler: Hardwarediagnose aktiv
    8192 8192 Vorausetzung Fehler: Antriebsdrehzahl ausserhalb Grenzen
    I hope, this will help you.
    Apr 2010
    Thanks for that. My car is actually getting a new mechatronics installed today (after new clutch pack 2 months ago) so hopefully I won't need to try this again, but good to know regardless.
    Any idea what it means by Neutral timeout - was I supposed to engage neutral during the procedure?
    Here's the English from Google translate:
    0 0 no abort
    1 1 Cancelled by User
    2 2 No Grd part predefinition (2)
    3 3 Prerequisites timeout (3)
    4 4 Neutral Switch little memory pressure (4)
    5 5 System Preparation n_An timeout (5)
    6 6 Neutral Switch GS13 timeout (6)
    7 7 Wait for engine starting out (7)
    8 8 System Preparation p_Speicher timeout (8)
    9 9 shaft W1 control timeout (9)
    10 10 K2 clutch zero position is not stable (10)
    11 11 clutch K1 zero position is not stable (11)
    12 12 Preparation Pickled p_Speicher timeout (12)
    13 13 Eingelegtpos Gangeinl G1 timeout implausible (13)
    14 14 Eingelegtpos Neutralsch GS13 timeout (14)
    15 15 Preparation sync point GS13 stable timeout (15)
    16 16 Preparation sync point n_An timeout (16)
    17 17 Kupplungswegrampe1 grinding point out (17)
    18 18 Kupplungswegrampe2 offset timeout (18)
    19 19 x-Nm Kupplungswegrampe3 timeout G1 (19)
    20 20 Kupplungswegrampe4 Kup_auf timeout (20)
    21 21 Kupplungswegrampe5 ZuPunkt_K1 timeout (21)
    22 22 Kupplungswegrampe6 Kup_auf timeout (22)
    23 23 Kupplungswegrampe7 Kup_auf timeout (23)
    24 24 Kupplungswegrampe8 timeout (24)
    25 25 Kupplungswegrampe9 timeout (25)
    26 26 Kupplungswegrampe10 Kup_auf timeout (26)
    28 28 Neutralpos. x_NM timeout after GS13 (28)
    29 29 Druckrampe2 WDK timeout (29)
    30 30 CheckMe Druckrampe2 WDK timeout (30)
    31 31 Druckrampe4 WDK timeout (31)
    32 32 Druckrampe3 WDK Werteableg1 timeout (32)
    33 33 Druckrampe5 WDK Werteableg2 timeout (33)
    34 34 WegDruck Char. NEw KupZu timeout or stable (34)
    35 35 Druckrampe6_Kupwegrampe8 Kup_auf timeout (35)
    36 36 Characteristics dropping out (36)
    37 37 Druckstuetzstelle implausible (37)
    38 38 Kupwegrampe11 Kup_auf timeout (38)
    39 39 Kupwegrampe12 Kup_auf timeout (39)
    40 40 Neutral Switch GS24 timeout (40)
    41 41 Neutral Switch GS57 timeout (41)
    42 42 Neutral Switch GS6R timeout (42)
    43 43 Neutral Switch K1 timeout (43)
    44 44 Neutral Switch K2 timeout (44)
    45 45 W2 wave control timeout (45)
    46 46 K1 wave control timeout (46)
    47 47 K2 timeout control shaft (47)
    48 48 Preparation Pickled K1 timeout (48)
    49 49 Preparation Pickled K2 timeout (49)
    50 50 Preparation Pickled GS13 timeout (50)
    51 51 Preparation Pickled GS24 timeout (51)
    52 52 Preparation Pickled GS57 timeout (52)
    53 53 Preparation Pickled GS6R timeout (53)
    54 54 Eingelegtpos Gangeinl G2 unlpausibel timeout (54)
    55 55 Eingelegtpos Gangeinl G3 timeout implausible (55)
    56 56 Eingelegtpos Gangeinl G4 timeout implausible (56)
    57 57 Eingelegtpos Gangeinl G5 timeout implausible (57)
    58 58 Eingelegtpos Gangeinl G6 timeout implausible (58)
    59 59 Eingelegtpos Gangeinl G7 timeout implausible (57)
    60 60 Eingelegtpos Gangeinl GR implausible timeout (60)
    61 61 Eingelegtpos Neutralsch GS24 timeout (61)
    62 62 Eingelegtpos Neutralsch GS57 timeout (62)
    63 63 Eingelegtpos Neutralsch GS6R timeout (63)
    64 64 Preparation sync point GS24 timeout stable (64)
    65 65 Preparation sync point GS65 timeout stable (65)
    66 66 Preparation sync point GS66 timeout stable (66)
    67 67 Preparation sync point W1 timeout stable (67)
    Kupplungswegrampe3 x 68 68 Nm-G2 timeout (68)
    Kupplungswegrampe3 x 69 69 Nm G3-out (69)
    Kupplungswegrampe3 x 70 70 Nm G4-Timeout (70)
    Kupplungswegrampe3 x 71 71 Nm G5-Timeout (71)
    Kupplungswegrampe3 x 72 72 Nm G6-Timeout (72)
    Kupplungswegrampe3 x 73 73 Nm G7-Timeout (73)
    Kupplungswegrampe3 x 74 74 Nm GR-Timeout (74)
    75 75 Kupplungswegrampe5 ZuPunkt_K2 timeout (75)
    83 83 Gangeinleg_Synchronpos. G2 timeout (83)
    84 84 Gangeinleg_Synchronpos. G3 timeout (84)
    85 85 Gangeinleg_Synchronpos. G4 timeout (85)
    86 86 Gangeinleg_Synchronpos. G5 timeout (86)
    87 87 Gangeinleg_Synchronpos. G6 timeout (87)
    88 88 Gangeinleg_Synchronpos. G7 timeout (88)
    89 89 Gangeinleg_Synchronpos. GR timeout (89)
    90 90 Neutralpos. x_NM timeout after GS24 (90)
    91 91 Neutralpos. x_NM timeout after GS57 (91)
    92 92 Neutralpos. after x_NM GS6R timeout (93)
    93 93 Neutral Switch n_An timeout (93)
    94 94 Preparation sync point W2 stable timeout (94)
    100 100 14 Kupwegrampe Kup_zu K1 timeout
    101 101 14 Kupwegrampe Kup_zu K2 timeout
    102 102 15 Kupwegrampe Kup_auf K1 timeout
    103 103 15 Kupwegrampe Kup_auf K2 timeout
    128 128 Precondition Error: Temperature
    256 256 prerequisite error: selector lever is not in P
    512 512 Precondition Error: Car-Speed. not NULL
    1024 1024 prerequisite errors: TG 1/2 failed
    2048 2048 prerequisite errors: battery voltage is low
    4096 4096 prerequisite error: Hardware Diagnostics active
    8192 8192 prerequisite errors: input speed limits outside
    Siberia.Omsk
    Ryan_R, you are welcome!
    About «Neutral timeout» I guess (IMHO) that in one of step, procedure «Basic Settings» has trying to go to Neutral (for any needed reason) and can’t to do that, waiting timeout has gone and procedure is stopped with reporting specific error (the 93 in this case).
    This behavior may reflect a problem with internal valves inside mechatronic (IMHO).
