Could be a vacuum leak. I had this on the missus' mk7 gti..... coupled with this the engine check light came on. It was the PCV valve......
Engine light came on due to ECU not being able to compensate for such a vacuum leak at idle.
Engine eventually began idling up to 2k then drop down to 1k.
Its possible that a technician has bumped a vacuum line off. Also check the engine oil dipstick. If the top "o" ring is worn it will also leak vacuum and cause a hissing noise.
Good luck.
Sent from my GT-I9505 using Tapatalk
