Sounds like the clock coil spring behind the steering wheel, quite easy to check.
Disconnect battery negative cable, ground yourself to the door striker of the car or chassis, turn steering wheel 1/4 degrees to the left, you should be able to feel a 'slot' behind the steering wheel, put a 8mm thick flat head screwdriver in there and turn it to the right, repeat it for the right side (turn your wheel 1/4 degrees right) to release the airbag, remove airbag connectors from clock coil spring (MAKE SURE YOU HAVE GROUNDED YOURSELF SO SO YOU DONT ACCIDENTLY SET THE AIRBAG OFF IN YOUR FACE FROM STATIC ELECTRICITY), remove the multispline holding the steering wheel on and remove steering wheel, clock coil spring is right behind it, I'm pretty sure you will find it's making the noise, spin it afew times to check..
Goodluck buddy.
