Results 1 to 9 of 9
Thread: Help needed with steering wheel swap. tsi to gti
    Feb 2013
    Melbourne, Victoria
    Hey guys, just needing some help/advice on a steering wheel swap.
    As many of you know i have a 77tsi with a non-multifunction wheel and i just bought a gti one.
    I have been told the airbag/front cover fits in so thats a positive. Just wondering if any of you know if i need to buy a new harness to get the MF buttons and paddles to work?
    And also, where in melbourne is a good place to go get it installed?
    Cheers,
    Deshan
    12' UG 77TSI | 17" Denvers + 17" BBS RS | Megan Racing Coilovers | Custom Exhaust System with GTI Tips | Thule 750 + Aero Bar | GTI Interior | 8000K HID | ANS-510 | Mk5 Carbon Wing |
    Build Thread
    VeeDubNation
    Suggest having a look at this thread: Flappy paddles steering wheel in Tiguan.
    The same steering wheel is used in the Tiguan and quite a few of us have changed out for flappy paddle versions.
    Though can't tell you what harness/SW control module you will have in a Golf 77tsi and whether this will work with a MFSW.
    Good luck though!
    Feb 2013
    Melbourne, Victoria
    Thanks! I will check it out!
    Yeah thats what im wanting to know, that if my harness doesn't get the MF buttons and paddles working, am I able to swap out the harness for the correct one?
    Build Thread
    VeeDubNation
    Dec 2008
    Sydney/Canberra
    Wiring should be the same.
    Pretty sure you'll need to upgrade the Steering Wheel Electronics control module, particularly if you don't have cruise control.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2013
    Melbourne, Victoria
    Quote Originally Posted by Umai Naa!! View Post
    I have the stock standard wheel, no MF buttons, no paddle shifts, etc.
    what does the control module look like? know where i can get the part numbers?
    Build Thread
    VeeDubNation
    Run a VCDS scan and compare against someone with a MFSW installed.
    This will tell you if you have the right steering wheel control module needed to support the upgraded wheel.
    Trinidad and Tobago
    ^^^this is the best advice. Safest thing to do would be to find out EXACTLY what you have installed so no guess work.
    Also this site can provide some background knowledge:
    VW Jetta-Golf GTI MFSW steering wheel swap or paddle shifter button retrofit
    Here's a scan of the associated modules from a Mk6 GTI:
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
    Component: BCM PQ35 M 103 0575
    Revision: 00103 AG
    Coding: 48180A3E9037F1C044080080240081E441501588536D8D6064 8000200000
    Shop #: WSC 01357 011 00200
    VCID: 3041C7B363978D9890B
    Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 26021 21 0512
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 020310 05 54 0403
    Coding: 0330AD
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Subsystem 4 - Part No: 1K8 951 605
    Component: LIN BACKUP HO H09 9002
    No fault code found.
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
    Component: AirbagVW10 037 0606
    Serial number: 003FKRA4GMK8
    Coding: 00003131
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3B5BE09FB2D17EC0359
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME79056650ZZZV
    Crash sensor for side airbag; passenger side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME3C646550ZZZZ
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME22025034ZZZ9
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME040F5042ZZZM
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
    Component: J0527 056 0111
    Coding: 0001632
    VCID: 76CD31AB0173E3A80A7
    Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Coding: 00000131
    Shop #: WSC 00000
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 870 D HW: 5K6 920 870 D
    Component: KOMBI H03 0305
    Serial number: 00000000000000
    Coding: 170B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 3449CBA39F8FB1B8F43
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0112
    Revision: H07 01 Serial number: 250210F2000406
    Coding: ED807F06500212000003
    VCID: 69F76AD740CD3C50975
    Feb 2013
    Melbourne, Victoria
    Thanks guys, but I got confirmation that the buttons will never work as my Golf is made after Ocotber 2012. So it has a different control module.
    The only way around it is to change the whole cars wiring loom, which is not a worthwhile task.
    So I just installed it for looks, as it looks better than the stock wheel. Also matches my GTI interior.
    Build Thread
    VeeDubNation
