Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: HELP! - Mechatronics Issues Mechanic Can't get head around
    Oct 2015
    VIC
    Quote Originally Posted by Snail Style View Post
    Can you give me the vin of the original vehicle and the donor vehicle?
    Most likely is you have the incorrect flywheel fitted. At a certain year break they changed the clutch design. Incorrect flywheel throws the adjustment out.
    Sent from my HTC_PN071 using Tapatalk
    Thanks for the reply.
    I can give you the VIN of my vehicle and engine no of the new engine? will that be enough?
    Can you explain how the engine flywheel could cause issues in the gearbox?
    Thanks
    Jul 2012
    Sinagra, Western Australia
    That won't help as need a second vin to cross reference. Only other option is to compare the part #s directly off the two flywheels.
    As i said, the thickness of the two flywheels are different. This causes the gearbox to not adapt the clutch points correctly and therefore the shuddering/banging etc.
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Oct 2015
    VIC
    The VIN Numbers are
    My Car - WVWZZZ1KZBM611414
    Engine - WVWZZZ1KZ9W513236
    Thanks for your help!
    Oct 2015
    VIC
    Hi Any Chance you could look this up please?
    Thanks in Advance
    Oct 2015
    VIC
    Resolved
    Quote Originally Posted by JRG2 View Post
    Thanks in Advance
    Hi All
    Thanks for eading and Sharing.
    For anyone who wants to know, it was the flywheel was different. The original was put back on and all is well.
    Big Thanks to Snail Style for his guidance!
    Nov 2009
    Hi All
    Great result!
    Jul 2015
    Sounds like you need someone with the right gear to adapt and reprogram the system.
