Help!! lost aircon vent spring clip. - Golf R
Hi Guys,
Was retrofitting a RNS510 and 9W7 bluetooth kit in Golf R today and when I went to pull the center console aircon vents out, one of the lower spring clips popped off and went flying into the resident black hole.
Does anyone know what the part number is?
TIA
Cheers,
LJ
Call your dealer's spare parts, give them your VIN and describe the part. They'll give you the part number. You can then do a search on the interwebs to see if that part number shows up any results, maybe even images, to give you an indication if it's the right part or not...
Thanks Corey..
Win Win.. Rang the dealership and described the part to them, and they said they'd have it in, in a couple of days. Fingers crossed.
PS. For those that are umming and ahhing about whether or not to go a RNS510 & 9W7 Bluetooth upgrade.. DO IT!!!!! well worth the $$ esp if you get the bits off ebay.
Everything is so synergistic..
LJ
- You may not post replies
- You may not edit your posts
Forum Rules
