I would think should be able to by the whole light assembly.... then code the MFD. Not sure thou. Good luck.
I think the Adidas GTI has these lights as well.
2011 MK6 GTI ED35
APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
Just finished helping someone do a complete retro fit including self levelling and AFS sensor on rear suspension. It is a massive job. If you want to just change the light units and not have them 'move' it is not too bad. Front bumper removal required plus new wiring adapter plugs and harnesses.
Still need to code of course.
You should have done what I'll do next - tick the box that says Xenons when you bought it![]()
GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
it's easy (if you have done it a few times aka revising the installs to work correctly), just need about >$3k (OEM headlights + uprated BCM + AFS module / sensor / wiring harness, 10-14pins adapters, headlight washer kit, etc etc) plus plenty of time, courage, tears & joy ...
have a look here for a start:
http://www.vwgolf.net.au/showthread....pgrade-and-AFS
as Ozram said above, tick the option when buying a new GTI, it's a lot easier, cheaper and a lot less headaches!
MINI Cooper S Clubman - FWD
Luckily mine has them standard. I have seen some cheap ones on ebay, but they are very poor quality. Even the light output from the xenons and the LED's is noticably reduced. Not sure if they have the dynamic cornering function either.
This is a big job,
The Body Control Module or Central Electronic Control Module
The Central Electronics Control Module (CECM) is situated above the pedals on the drivers side and controls all the lights in the car, monitors them, controls what appears in the MFD under the lights menu, controls the leaving home and coming home lights function, controls the horn(s) and other features. There are different variants of this module called the Medium and the Highline, the latter is required for fog lights, bi-xenons and other features.
Adaptive Front Lighting System (AFS) is in charge or "auto" level the Bixenon headlights depending of the road conditions,
.:Polo 6R 77TSI
.:Golf MK6 GTI
II Kraftwerk
I'm keen on a pair of led lamps for my car, and these look good from win power...
2009-2012 VW Golf 6 Headlight with 15 LED DRL and Bi-xenon Projector,View Golf 6 Headlight,Winpower 2009-2012 VW Golf 6 Headlight Product Details from Guangzhou Hualuying Electronics Ltd. on Alibaba.com
...anyone got experience of their quality etc?
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
He is advertising them as xenons but hen talks about HID so I'm a little confused about what they are exactly but if they are true xenons they will be illegal on your car without pop up washers and auto levellers.
