Page 29 of 36 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 360
Thread: Headlight / Headlamp Upgrades (Bi-Xenon / HID / LED / Replicas)
  1. #281
    Nov 2009
    I'd be contacting the seller requesting more info, and, failing that you could try the US forums (VWVortex etc) or Ross-Tech themselves (if you own VCDS). Beyond that, I'd say you're out of luck - coding the Central Electrics module for a replica set of lights possibly intended for foreign market cars and differing versions of the Central Electrics module sounds like a world of pain.
  2. #282
    Sunshine Coast, Qld
    Quote Originally Posted by AdamD View Post
    Well there are others on here that have got them and are working fine and figured it would be the best [lace to first. I mean isnt that what a forum is about? so I was hoping for a little info as I am no pro when it comes to the Central Electrics module at all.... no even newbie!!!
  3. #283
    Nov 2009
    Quote Originally Posted by TeamCrash View Post
    Apologies if I offended you there; your post is entirely legitimate and I'm not trying to imply otherwise. Hope you track down the info you're after!
  4. #284
    Oct 2010
    With issues surrounding the legal use of the hid's, I'm wondering whether these oem headlights would be legal if I were to install but just transfer my current halogens?
    OEM Euro VW Golf R R20 MK6 Black Xenon Headlights Housings - BKS-Tuning
    MY11 118TSI - sports kit/sunroof/Mdi - United Grey
  5. #285
    Apr 2010
    If you're going to spend that much on just the housings I'd recommend you also get new brighter halogen bulbs that complete the look.
    Are you sure they're to be used with halogens since it mentions transferring ballasts, etc?
  6. #286
    Oct 2010
    Yeah I think I'm getting my bits mixed up. New Halogens would be a great idea I agree
    New Style HID Replica Headlights - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    I think that particular one, not being OEM, is designed that the existing halogens will fit (to a certain extent.)
    "The lights have a 10 pin harness and is designed to be used as an upgrade for halogen equipped cars. H7 bulbs fit in there with no problem. The rear cover is pre-drilled to run wiring for your HID kit. If you decide to use halogen bulbs, you can always put some duct tape or a grommet to cover up the hole."
  7. #287
    Apr 2010
    Adelaide, South Australia
    GTI carbon steel g, leather, mdi, A.C.C., park parallel assist & RVC, dynaudio, sunroof, R-tails, RNS510, 9WZ, LED reg
  8. #288
    Oct 2010
    yep, Those look about right.
    Probably looking to get a set and run some bright halogens through them.
  9. #289
    Apr 2010
    let me know i am considering that myself
  10. #290
    Can genuine golf led headlights fit standard GTi?
    Is it easy/possible to retro fit golf GTi 35 drl/led lights onto my stock GTi?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
