Page 28 of 36 FirstFirst ... 182627282930 ... LastLast
Results 271 to 280 of 360
Thread: Headlight / Headlamp Upgrades (Bi-Xenon / HID / LED / Replicas)
  1. #271
    Probably an ignorant question, but what do the headlight washers have to do with installing these lights? Are the washers not controlled independently (ie, through the wiper system which you control internally)? Are they wired into the headlight assembly somehow?
    I would love the get these on my GTI... just want an easy way to do it!
  2. #272
    Pacific Paradise QLD
    Quote Originally Posted by SAINIside View Post
    As I understand it they are to keep the glass clean so as not to let the beams flare due to dirt distorting the light and blind people due to their brightness
    I was also told not to put headlight protectors on for the same reason..
    Some earlier model cars also had wipers on the headlights as well as washers.
    The Passat ones wash every 5th time the wipers go on.
    Will be a long time between washes in Qld as we have had 2 hrs of rain since 29th June
  3. #273
    I get that they are there to keep the headlight clean and not interfere with beam (as these xenon type ones are prone to flare more than the standard headlights). But at the end of the day, they are not automatic. It is up to the driver to activate them just like the wipers.
    I'm wondering more about why people say if you retrofit xenons, then you also have to fit washers, but if the car comes with washers already, then do they need some kind of special wiring also?
    Also - anyone know where I can find M4RKO's write-up... I can't seem to find it!
    2013 GTI Candy White | DSG | Leather | Sunroof | Privacy Tint | OSIR Carbon Fibre Mirror Caps | Gloss Black Emblems | Gloss Black GTC GT-CX 18x8.5 Wheels |
  4. #274
    Whether you agree or not it is an ADR rule so must be complied with to be legal
    Not all rules are logical but still must be complied with.
    They will of course be wired in and have a control module somewhere to make them work.
    Possible a recoding will activate the required bits if they are fitted.
    Mine came with the rather expensive package.
  5. #275
    Apr 2010
    What about when you use the windscreen washers? Actually I thought it was the 5th time you used the windscreen washers, not just the wipers.
  6. #276
    You are correct The salesman told me wipers,but on reading the manual it says the first and then every 5th time the washers are used.
    Still wont get used much in QLD
  7. #277
    Apr 2010
    nw, I often use the ashers regardless of rain since they get dirty fairly quickly and there's a nice smell when you use the proper VW fluid.
  8. #278
    Aspendale, VIC
    Here you go mate.
    MK6 Front Bumper Removal
    There are allot of rules regarding mods, not all logical but rules non the less.
    Just use a common sense approach and you'll be fine. I've aligned my lights accordingly and can guarantee its not blinding any drivers. What makes it illegal is it doesn't have a $1k auto-levelling motor... ?!?
  9. #279
    Jan 2009
    Quote Originally Posted by XQUIZT View Post
    The automatic levelling system is supposed to adjust the headlight beam according to vehicle load (i.e. passengers and/or cargo) via sensors attached to the suspension.
    It's quite easy to dazzle oncoming traffic if the beam isn't adjusted for load (even with halogen bulbs, let alone gas discharge bulbs) which is why nearly all European cars come with a manually-operated beam level adjuster.
    However, the regulations state that this has to done automatically for cars with gas discharge bulbs.
    The high output of gas discharge bulbs (typically 3200 lumen for a D1S bulb, compared to 1500 lumen for a H7 bulb) inevitably means that their usage is going to be strictly regulated.
  10. #280
    Sunshine Coast, Qld
    Chinese headlamps
    I finally got the chance to do the coding for the Chinese replica headlights. After trying the codes suggested we got nothing. We hit the forums in hope of (pardon the pun) getting some light.
    One thread on here said to change byte 15 or 18 (I can't remember) to E4. This byte was about the whole cars lighting system and with warning suggesting not to change this.
    With nothing really to lose we change the byte, lights now set for a scirocco RoW. And hello the LED running lights were on. Only problem the warning for the R taillights is now on. We tried a number of other tick and flick options and even reverted back to the old code in the hope that it might just work.
    I had two options no error on the MDF and no LED's or LED's with the error light. I choose the error option as the reason for buy the replicas was for the LED option after all.
    On my way home I also discovered another problem. To have the LED's on the lights need to be on the park light option. I've turned the drls off on the MDF but still only work when watched on parkers.
    ideas that may help? I am sure it just in the coding that we have forgotten to tick or not tick
