Page 10 of 36 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 360
Thread: Headlight / Headlamp Upgrades (Bi-Xenon / HID / LED / Replicas)
  1. #91
    Dec 2009
    Is that squashed hexagonal light actually part of the headlight or a reflection of a light on the roof of the building?
    EDIT - Just read further on the linked thread that it is a light.
    2019 BMW M3 CS
  2. #92
    Jul 2007
    Sydney - the regressing city
    Quote Originally Posted by AdamD View Post
    Also, the xenons are a different colour (whiter light) to the fog lights and parkers
    Xenons come in a variety of colours which is denoted by the colour temperature in kelvins - 3000K xenons are yellow, 6000K white, 8000K blue and 12000K purple.
  3. #93
    Jan 2008
    Quote Originally Posted by sci_fianime View Post
    And 4300K to 4800K are oem and provide the most light.
    More info here
    Retrofitting Xenons (HID) Lighting to reflector housings
  4. #94
    Dec 2009
    Re: Bi-Xenon on GTI (Pics + Info)
    Quote Originally Posted by coreying
    I'm actually sure that the DRL light for the Xenon is the 'high beam light' on an alternative beam mode. So that would be the two lights closer to the central grill - the same position as the standard DRL lights.
    Those inner lights are simply the indicators. The high and dipped beam come from the one projector-style xenon unit, ie the outer ones within the headlight enclosure, using a shutter to switch from one beam to the other. Hence, I believe, the term "bi-xenon".
    AFAIK from other forums, the DRL function is simply the low beam xenon. I can confirm this personally in about a month (!).
    Andrew
  5. #95
    Feb 2010
    Hi Guys, not sure if you are aware but the current Xenon config setup on the GTI6 is not the way it should be (aknowledged by VW). Check this tread:
    http://www.vwwatercooled.org.au/newf...ad.php?t=40915
    As it stands, your xenons (low beam) are used as the DRL - regardless of the light switch position. This means even your rear light are used non-stop.
    So, theoretically, your light sensor (on the windsreen) is used only for the AirCon\Radio\Steering wheel buttons to lit when driving into a dark area.
    Hope this makes sense.
  6. #96
    Jul 2007
    Quote Originally Posted by Maverick View Post
    Personally, I found that I see better with a 6000K burner...
  7. #97
    Nov 2009
    NSW
    Quote Originally Posted by Sute View Post
    So what is the correct operation? Which light is the correct DRL?
    2010 5 DR MK6 GTI|DSG|CARBON STEEL|18" DETROIT|ACC|BI-XENON|LEATHER|SUNROOF|DYNAUDIO|SATNAV|MDI|PREMIUM BT|TINTS|EXTENDED WARRANTY| In garage
  8. #98
    Nov 2009
    NSW
    So what should the CORRECT functionality be?
  9. #99
    Jan 2008
    It's an illusion.
    Colour temperature has nothing to do with light output.
    4300k puts out the most light (although some osram 4800k bulbs are quite good performers).
  10. #100
    Feb 2010
    From what I was told, the hexagonal shape (little light under the xenons) should have been the DRL but wasn't bright enough for the latest Euro laws. You could check this yourself if you put the light switch to "park" setting.
    What's is Correct setting? Who knows, but comparing it to the non xenon GTIs, I guess (IMO) it should be:
    Light Switch '0' - only DRL (little parking lights) - nothing at the rear
    Light Switch 'auto' - depending on the ambient light (all lights on or all off except for the DRL)
    Light Switch 'parking' - only DRL (little parking lights) - and the rear lights
    Light Switch 'on' - every light on regardless of the ambient light.
    This is how it is on other cars, so I believe should be the same. Plus, here in Oz, DRL are not compulsory (not yet) as in Europe so why should we shorten the life of the bulbs. I know they last longer but the moment you are outside the warranty - then it will happen.
    Cheers.
