Page 30 of 36 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 360
Thread: Headlight / Headlamp Upgrades (Bi-Xenon / HID / LED / Replicas)
  1. #291
    Jun 2009
    Quote Originally Posted by sVWatt View Post
    Is it easy/possible to retro fit golf GTi 35 drl/led lights onto my stock GTi?
    If you have halogen headlights and try to swap xenon bulbs you will have issues with the eletric's/coding from what i have read.
    Happy to be corrected though.
  2. #292
    Jan 2013
    Brisbane, The Gap
    I would think should be able to by the whole light assembly.... then code the MFD. Not sure thou. Good luck.
    I think the Adidas GTI has these lights as well.
    2011 MK6 GTI ED35
    APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
    MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
  3. #293
    Apr 2009
    Just finished helping someone do a complete retro fit including self levelling and AFS sensor on rear suspension. It is a massive job. If you want to just change the light units and not have them 'move' it is not too bad. Front bumper removal required plus new wiring adapter plugs and harnesses.
    Still need to code of course.
    You should have done what I'll do next - tick the box that says Xenons when you bought it
    GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
  4. #294
    Jan 2011
    Brisbane - QLD
    it's easy (if you have done it a few times aka revising the installs to work correctly), just need about >$3k (OEM headlights + uprated BCM + AFS module / sensor / wiring harness, 10-14pins adapters, headlight washer kit, etc etc) plus plenty of time, courage, tears & joy ...
    have a look here for a start:
    http://www.vwgolf.net.au/showthread....pgrade-and-AFS
    as Ozram said above, tick the option when buying a new GTI, it's a lot easier, cheaper and a lot less headaches!
    MINI Cooper S Clubman - FWD
  5. #295
    Jul 2011
    AU
    Luckily mine has them standard. I have seen some cheap ones on ebay, but they are very poor quality. Even the light output from the xenons and the LED's is noticably reduced. Not sure if they have the dynamic cornering function either.
  6. #296
    Quote Originally Posted by Ozram View Post
    Yeh just read some the DIY links. So not worrying about the moving part. What is the BCM and AFS ?
    Maybe the Mars plug and plays would be easier?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
  7. #297
    And I really appreciate it man!
    .:Polo 6R 77TSI
    .:Golf MK6 GTI
    II Kraftwerk
  8. #298
    This is a big job,
    The Body Control Module or Central Electronic Control Module
    The Central Electronics Control Module (CECM) is situated above the pedals on the drivers side and controls all the lights in the car, monitors them, controls what appears in the MFD under the lights menu, controls the leaving home and coming home lights function, controls the horn(s) and other features. There are different variants of this module called the Medium and the Highline, the latter is required for fog lights, bi-xenons and other features.
    Adaptive Front Lighting System (AFS) is in charge or "auto" level the Bixenon headlights depending of the road conditions,
    .:Polo 6R 77TSI
    .:Golf MK6 GTI
    II Kraftwerk
  9. #299
    Win Power LED HID Lamps
  10. #300
    May 2012
    He is advertising them as xenons but hen talks about HID so I'm a little confused about what they are exactly but if they are true xenons they will be illegal on your car without pop up washers and auto levellers.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
