If you are after more light to see better then I recommend Philips X-treme H1 55W and Osram 65W H7 Rallye (depending on what fitting your headlights take - it is probably mentioned somewhere in your owner's manual).
If you really must have the blue/white look (and don't mind the reduced output and/or shorter life that comes with that at no extra charge) try looking at the powerbulbs UK website. You may want to change your parker globes as well if they are a bit "yellow" (but they are a lot harder to change than headlight globes on some VW lights).
