Should be able to do it through the centre MFD under vehicle settings.
Hi All,
I know this has been covered, but I have attempted the process (engine off, flash high beam - left indicate, wait then turn engine on, wait etc..) and I still continue to have DRL.
Is it different for MY13 GTIs?
Thanks for any input as it is doing my head in.
Justin
MK6 CS GTI
Mine is through the MFD "Lights&Vision".........
2011 MK6 GTI ED35
APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
This is all I get under that menu
very strange...mine is a MY11, seems odd it wouldn't exist for MY13
MK6 CS GTI
Perhaps it's because I have Xenons with DRL's..... my option is between "Footwell Light" and "Lane ch. Flash".
2011 MK6 GTI ED35
Wonder if it is a firmware version issue? Ie my car running the old ECU software?
Can you take a photo of what you see and I'll raise it with VW
I have a photo but be stuffed if I can attach it.....I've tried... It is the same as your MFD with an extra option.
2011 MK6 GTI ED35
Mine is through the MFD. if you can't see it, you can switch DRL off via VAGCOM. I did this for another forum member when installing his new headlights![]()
