The problem is that FOGS are SUPPOSED to be yellow but in this day and age of enlightened engineers they choose to make them white.
In the good old days when sanity prevailed, fog lights had yellow light which shines better through fog than does white light.
Now they call them "other" lights and they cause more trouble than enough.
To wit Subaru WRX with so called Fogs which are in fact about 8" driving lights and blind you at 500metres.
Yellow light does not glare like white light.
Dont think flashing any membership card would get you off if they want to push the point.
The problem with the yellow lense ones is that they are very distracting when used when it is not foggy. Its true that yellow or yellow-ish light penetrates fog a little better, but the important thing is to make sure they are aimed properly. You don't want them to shine into the fog because they will just reflect and refract through the water droplets and make it harder to see, pretty well regardless of what colour it is. Blue and violet light is not good for fog lights because that part of the spectrum scatters more. That's why most fog lights are still halogen, which is about 2700-3000K. This is generally considered to be in the yellow spectrum.
They need to be aimed downward and slightly outward so they illuminate the road surface so you can see the road and the lines.
We shouldn't confuse well engineered factory fog lights that are set up properly, with poorly design aftermarket fog lights that are usually incorrectly set up and aimed incorrectly. These have given all fog lights a bad name.
Totally agree with the WRX lights. You're right, they are actually more like driving lights
