Results 1 to 8 of 8
Thread: H22 Parking Sensor Buzzer Speaker
    Jun 2021
    Wollongong NSW
    As in the title I need to replace the speaker for Parking assist
    Too much conflicting advice on where it is located
    So say remove glovebox to be located behind it
    Others say remove the wipers and located under it drivers side
    So say you need to partially remove the Dash
    Im looking for the location to it in my MK6R 2011
    And hopefully not too much moola to buy another on
    cheers
    Golf Mk6 R
    I believe the electronic module for the parking sensors is located under the windscreen cowl.
    But the little speaker itself will be inside the cabin. According to Google, for a Passat its in the drivers footwell or lower dash area. Not sure if the Golf is the same sport but might be worth checking.
    Senzori De Parcare Oem sau AM - Page 38 - Passat B6 - vwForum.ro
    Mornington Peninsula, VIC
    I have done it on the Passat; I hope you have small hands
    It will be under the dash somewhere; you would not be able to hear it if it were too far from the driver.
    Do the Golfs have the little glovebox to the right of the steering wheel? It was behind and up from there, almost behind the cluster area.
    Also on the part, you can get them super cheap online ~$10-20 or go to VW if you need it sooner was like $120+ ouch
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jun 2021
    Wollongong NSW
    VW Golf MK6 2009-2013 PDC Parking sensor Buzzer Speaker fault H22 front location replacement RHD UK - YouTube
    This the the video base on a UK MK6 TSi was wondering if this is the location at firewall
    Is this the same for a MK6 R location ?
    Golf Mk6 R
    Jun 2021
    Wollongong NSW
    Passat would be different from Golf ?
    Golf Mk6 R
    Jun 2021
    Wollongong NSW
    This is confusing Passat same as Golf confusion over the Internet
    Golf Mk6 R
    Jun 2021
    Wollongong NSW
    Also a question would the Front H22 and the rear H15 be the same same sensor ?
    Golf Mk6 R
    Quote Originally Posted by GolfR64 View Post
    It would be very similar, also wow that's also cool it is in the same general location as the Passat, but with an access hole from the outside.
    Part numbers will be the same front and rear.
