Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: GTI Low speed throttle (on/off switch)
    Feb 2009
    Sydney, Australia
    The MK6 and MKV throttle is identical from everything I've seen... (at least in the case of the GTI and R's etc)
    Jul 2011
    Brisbane, Queensland
    Quote Originally Posted by slam View Post
    Hi Hooba,
    ...the car was very happy to crawl uphill in 1st gear between 900 - 1,200rpm.
    It's impossible to do the same in the GTi.
    I actually found this to be really easy in the GTI, especially when you compare it with something like a Golf 77TSI which I could not get up some of the hills in Paddington without unacceptable levels of clutch abuse.
    Dave
    New Ride: MY19 PW R Special Edition
    Past: MY12 5dr CW Golf GTI Manual
    Mar 2010
    Witness Protection
    Hi Hooba,
    I've noticed exactly the same thing in my manual Mk6 GTi. I owned a manual Mk5 TDi before getting the GTi and the low speed throttle control was definitely much smoother in the TDi. It was so easy to drive the TDi in uphill stop / start traffic - the car was very happy to crawl uphill in 1st gear between 900 - 1,200rpm.
    Does anyone know if the Mk5 Golf had fly by wire throttle or not?
    I've had exactly the same experience with a Mk5 TDi 1.9 up the back streets of Balmoral, but I just put that down to the diesel having more torque down low.
    May 2011
    NSW
    Quote Originally Posted by hooba View Post
    The Mk6 GTi has 280Nm from 1,800rpm onwards, and I believe the Mk5 1.9 TDi has 250Nm from 1,900Nm onwards. Not sure what the torque curves look like around 1,000 - 1,500rpm for both engines?
    MY12 Mk6 5 Door GTI | Carbon Steel | Manual | Leather | Adaptive Chassis Control | Bluetooth | MDI | Tint |
