Results 1 to 6 of 6
Thread: Gti high oil temp
    Mar 2010
    Gti high oil temp
    Hi Guys,
    I had my GTI's Radiator replaced under warranty about a year ago, and ever since have had high engine oil temps.
    They are between 105 and 110 degrees regardless of ambient temp and driving conditions.
    Before the radiator replacement, they used to hover between 96 and 103 ( Summer and High Traffic ).
    Whenever I turn the car off, the fans will kick in and run for a while, which is also a bit odd. If they did kick in before, it was over pretty quickly. Now they run for several minutes.
    Not sure why it would rise like this with just a radiator replacement. Have had it checked out by my usual mechanic and VW when it goes for work, but nothing is found.
    I am only assuming it is the radiator, because I never had the issue before it went in for the replacement.
    Just think its a bit high for normal day to day driving.
    Has anyone else had high temps like this?
    Gti high oil temp-gti-temp-2-jpg
    Thanks
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
    May 2011
    Quote Originally Posted by Sir_GTI View Post
    Hi Guys,
    Thanks
    Does sound high to me, my stock MY12 GTI sits on around 96 to 103 max on a hot day !
    Was it a new radiator that went back in, or a re-core.
    Why was it changed ?
    Sold - CW Mk6 MY12 GTI 5 Door DSG, Sunroof, Leather, RNS510, MDI, Tints, Lakin plate holders, BT & RVC, projected 'GTI' door lights
    Current - Lapiz blue mk7 Golf R DSG fully optioned.
    Dec 2009
    Sydney NSW
    In heavy stop-start traffic summer traffic I see temps between 103-106, and this has been consistent since new (2009)
    mk VI GTI, manual, reflex silver, basic
    Sep 2010
    Southern Highlands NSW
    mine sits at 105 most of the time.... a few degrees more shouldnt be of concern
    is it possible maybe you're running a different brand or viscosity oil which is causing a slightly higher reading?
    Polo GTI
    T-Roc R
    Tiguan R
    Jul 2011
    Aust
    I've had my at 118.
    So long as below 130, she'll be right.
    I've noticed in the past fresh oil brings averages down, then 3000-4000km in averages rise.
    Mar 2010
    Thanks all for the replies.
    The radiator was leaking from the top passenger side. VW did the replacement under warranty.
    I have the car serviced at my usual mechanics, and the oils have not changed.
    It is just weird that it would vary so much. The car loses power, and becomes really sluggish, like heat soak when it gets to 105 and above.
    I would assume that VW use the radiator as an oil cooler for the DSG too ... maybe.
    Cruising at highway speeds the temp will sit between 105 - 107, and would of assumed the increased airflow would lower the temps, but not until you slow down.
    I almost feel like VW might of put something in the coolant to close the leak, rather than replace the radiator.... who knows.
