There are two options here
A) The pre delivery guy whilst putting your car through it's paces in the car park drifted into another car and they're quickly repairing your car or
B) As part of the pre delivery they scan the car for faults (the car is put into a sleep mode when it comes out from Germany and it woken when it gets to the dealer) and they found a problem with a module not responding or throwing errors so they will look into and replace the module if required before you take the car.
Look at it this way, how would you like it to take delivery of the car and for a fault to develop that leaves you stuck in the middle of peak hour traffic or for it to turn out that the main harness is incorrect and that as you've taken delivery VWA has decided that the dealer instead of replacing the car for you can instead fit the $5000 harness which involves pulling the car to pieces and hundreds of connectors to be plugged and unplugged which will take days?
Better to wait and let them sort it out properly.
The VAS 5051 is the diagnostics computer they use to "talk" to the car. There's also versions like the VAS 5052 (portable) and VAS 5053 but VAS 5051 is the mose common and it rolls around on a stand with wheels.
