Results 1 to 4 of 4
Thread: RCD510 - Upgrading speaers and Adding amps
    Nov 2009
    QLD
    Hi guys, did a quick search for this topic but it hasnt specifically been covered. i apologise in advance if it has.
    I have a GTI on the way with a standard audio system. I have a pretty good quality system that i have in my current car that I would like to put in if i can. Specifically i am wondering what the specs are for the RCD510. Does it have twin RCA outs? any feedback is appreciated
    Jan 2008
    No it doesn't have twin RCA out. It has high level or low level outputs (there's some info on my website in the RNS 510 section about setting it up for use with an amp (it's a Vagcom/VCDS change) and this will tell you the voltage).
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Brandon89 View Post
    It's probably because this is the MK6 forum, you should go over to the VW Car Audio and Electronics and ask there.
    Nov 2009
    QLD
    thanks Maverick. yeah coreying, did complete search. but shouldve posted it in there
