Results 11 to 20 of 26
Thread: GTD Wouldn't Start
    Lake Macquarie
    I had my battery go flat on me after 4 weeks of owning my car. I do long distances everyday. I charged it overnight and all has been well for the last 8 months.
    I noticed that if i did not close my hatch properly (or the doors or bonnet) the mdf display stays lit up (does not go to sleep) and shows the hatch/door/bonnet that is open. I suspect that this was the cause of my battery drain
    Problem with the hatch is that is not obvious that it has not closed properly (more obvious for a door). i suspect that this was the cause of my battery issue ... ie ..... user error.
    Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
    Nov 2009
    Quote Originally Posted by Klink1313 View Post
    I've checked this in my car; from memory the display will turn off - after about 20 minutes or so. (I occasionally leave the bonnet open for the hot air to dissipate after a drive on a hot day.)
    I turned on the door lock/unlock chirp with VCDS for this very reason. Now if it doesn't chirp when I lock the car, I know something's not quite shut. (And that something can often be the tailgate - if you've opened it to take something out after getting out of the car, it's not like you'll see the indication in the MFD.)
    Mine was flat on Saturday morning. The car in question is a June 2011 GTI. RACQ guy knew the problem straight away. Short journeys each day and not locking the car when in my garage at night. According to him the cars electronics do not go to sleep unless you lock the vehicle and over time will slowly drain the battery. This coupled with 10km round trip each day was enough to cause the battery to get to a low enough level not to be able to start the car. I bought a charger and charged it fully and will do so every six months from now on.
    Adelaide hills, SA
    Quote Originally Posted by Brycem View Post
    That's right. The drain from the battery until the modules go to sleep is around 300mA compared to 20mA or less, when you lock the car with all doors properly shut.
    Apr 2011
    Eastern suburbs, Victoria
    Never knew this fact about locked versus unlocked power drain. Although I always lock my car in the garage overnight it is good to know about this. Never stop learning I guess.
    Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
    Viagra on 4 wheels !!
    "If you can't fix it with a hammer then it must be an electrical problem"
    Camberwell, Vic
    Quote Originally Posted by AdamD View Post
    As well as it is easy to reach into a pocket and press a button to lock or unlock and inadvertently push the middle one to unlock the boot - which it does but there's no obvious sign the boot is unlocked and open
    2010 R36 (MY10.5), Biscay Blue, RNS510, MDI, Electric tailgate, sunroof, Superchips remap - SOLD
    2016 Octavia VRS wagon, moon white, Tech Pack, 18" black pack, electric boot, panoramic sunroof, Bluefin
    Jun 2011
    Townsville
    Just got the battery tested at Battery World.
    Printout they gave me shows:
    Volts: 12.58V
    Measured: 635 CCA
    Rating: 600 CCA
    They said that it should be up around 13.5 Volts... and not 12.58 after only 7 months, and that I should go see VW.
    Jan 2012
    Epping, NSW
    That is a total crock. The charged voltage of a car battery is 2.1V per cell, with 6cells=12.6V. Your car battery provides plenty of cranking amps, it is no where near end of life. The only time it would read 13.5-14V is when the engine is running, and they definitely wouldn't want to be load testing it like that (blown alternator probably).
    Adelaide hills, SA
    Quote Originally Posted by justin View Post
    Volts: 12.58V
    Measured: 635 CCA
    Rating: 300 CCA
    It's more likely 300CCA Measured and the Rating is 635CCA, which would be most likely flat battery or the battery that needs replacing.
    Jun 2011
    Townsville
    Oh whoop! I meant 600, and not 300 sorry. Have corrected my post.
    ---------- Post added at 03:46 PM ---------- Previous post was at 03:45 PM ----------
    Booked it in to get a new battery (which they have told me should be under warranty) next Tuesday.
