Sure you don't have a boost leak? If one of the turbo / supercharger hoses is damaged or not sealing it can give a squealing noise.
I have the 118 TSI and upon acceleration there is a squeal noise coming from the front end. I took it to the dealer and the tech was honest and said he had just read about this problem in the GT TSI that the water pump solenoid which is associated with the supercharger clutch assembly make a squeal for a brief time when accelerating.
The tech bulletin stated there was no known fix from VW but that my warranty would not be affected if there was a problem later on?
Has anyone else had this occur. It is a June 17th Tech bulletin so just a recent problem. Mine is 5000km and 2 months old.
The squeal is driving me nuts as I now consciously listen for it. I first thought it was a brake pad not clearing but it is definitely upon acceleration and the supercharger clutch sounds more like the area,
2018 Skoda Superb TDI
2010 Skoda Superb TDI
2009 Golf VI 118 TSI
2006 Multivan TDI SOLD
No that would last longer this is a brief 1-2 second squeal, I've had a turbo hose leak and it's not the same. This has a metallic squeal so the clutch solenoid idea seems to point in the right direction.
sorry, i couldnt help it - tyres braking traction?![]()
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Hamster stress?
That's funny,
had the water pump changed on mine at 7000km
http://www.golfmk6.com/forums/showthread.php?t=1799
Youtube video on a 1.4 rocco
http://www.youtube.com/watch?v=Q2XVbJmLEuU
This is exactly what I have going on with the acceleration squeak, the utube vision seems a bit higher in the rev range than mine and possibly associated witha gear change. Mine is a little lower in the rev range but consistent on the beginning of acceleration. As stated in original post there is a Tech Bulletin issued by VW that says they know of the problem but have no fix. I would like to see how Burwin got the replacement waterpump through as my VW dealer won't attempt anything until it is authorised as they won't be reimbursed by VW for the replacement part.
Thanks for the help.
Another youtube video of a user with the same problem:
http://www.youtube.com/watch?v=GLu73I1QD7M
Is this a widespread problem? Is there anyone with a 118TSI that does NOT have this problem?
I don't want to believe, but it seems a common problem on MKVI 118TSI now. Although I am still waiting for my new golf, I am so worried about this problem.
