A Ross-Tech VCDS cable is definately on my Christmas list, and at this stage unfortunately it will more than likely be Christmas before I'll be able to splurge that much on myself/car. But they are definately worth it from what I have heard and read.
Which is why I have been considering some of those cheap dongles off Ebay or an OBDEleven. Fairly inexpensive but will get the job done for the meantime and hopefully keep me out of trouble.
I've managed to narrow down my spark plug options, I'm planning to get some NGK iridium's with the standard 0.8mm gap (the APR guy says they usually gap them at 0.55mm but that's usually for cars running stage 2 with 25psi+ boost. Which I'm pretty sure I'm not running. A friend with a mk6 golf is getting new gauges in the next couple of weeks so I plan to borrow his old one to see just how much boost I am running. But standard gapped plugs should do me and the car a world of good.
As for that pipe circled in blue. I'm fairly certain that it is the original OEM one from factory. I could be wrong how ever I shall try to investigate that when I change my plugs over this week/weekend. I am also thinking my PCV may be on it's way out.
'Apparently' there is not suppose to be any air escaping out the top of the PCV (according to the APR guy) I am yet to ask VW this question, probably a job for tomorrow. Only a very slight amount of air but it does seem strange. Next on my to do list is watch some videos and do some research into checking the PCV is working correctly, and if not hopefully that is covered by my warranty
Please keep in mind that before purchasing my lovely Euro beast, I drove predominantly Jap, so similar workings but there is definitely a difference in machines and their temperamental issues. I seem to be learning all over again. Which I must say I am actually enjoying
MY12.5 Golf GTI - limited mods
