Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Golf R wont start (SOLVED: Flat battery)
  1. #21
    Dec 2009
    Kew, VIC
    Dead battery — but check for loose or corroded terminals first.
  2. #22
    Ok, thanks guys, yeah i just got the multimetre out and it is the battery. Only has 10.20volts off and drops to 5 volts when you kick it over. So looks like a new battery. Thanks for all your help
  3. #23
    Also when putting the new battery in, is there any procedures to follow or tricks to it?
  4. #24
    Dec 2014
    Kellyville, NSW
    Yep, sure is. Make sure to take the old one out ...... boom tish. Soz, couldn't resist.
  5. #25
    Haha, good one. Ill give you that
  6. #26
    Dec 2008
    Sydney/Canberra
    Negative terminal off first, negative terminal on last.
    Basic tools only. Ratchet, long extension and 13mm socket, and a 10mm spanner. Should take you about 5mins tops.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  7. #27
    Jun 2011
    Sydney NSW
    You may need to enter the security code for the radio. If you have not got it, you will have to talk to your dealer. They are supposed to provide it free, but many charge because they may have to physically remove the radio to get the stamped serial number from which they generate the code.
  8. #28
    Dec 2008
    Sydney/Canberra
    Only need the code if you put it in another car.
    '01 Beetle 2.0
  9. #29
    Jul 2012
    Sinagra, Western Australia
    As above, but you will need to reset your one touch windows and clock.
  10. #30
    Jan 2015
    HI guys! I have the same symptoms as the OP as well, does that mean my battery is flat as well? I have a 2010 Golf R. When I disconnect the negative terminal of the battery the alarm goes off......... Would someone please be able to help me and provide me with some advice on how to get around this Sorry I am kind of new to VW cars( Thanks in advanced.
    Also I am looking at some replacement batteries just in case it is a dead battery. A bit confused as to which one is right....my budgets around the 200-300 mark. Just want something reliable.....Will the ones from K-Mart suffice? As they are within walking distance from me...
