The Subaru BRZ is not due out for another 6 weeks apparently, but a back to back comparison between the BRZ and Toyota FT86 Coupe is something I’d look into. Why ... to see what all the fuss is about .. and ... to compare the different suspension setups of each coupe. It has been stated that the only difference in suspension tune between the BRZ and FT86 is that the BRZ has about 10% stiffer front springs than the FT86 to give it more of that Subaru WRX feel/suspension tune.
How does this relate to a Volkswagen Golf I hear you ask. Well:
My Golf GTI with DCC on standard springs would appear to be akin to the Toyota FT86 where the front springs are relatively softer than the rear springs, with not so good low speed compression ride comfort as race-car driver Randy Pobst noted in the Motor Trend article.
My Golf GTI + DCC with addition of Driver Gear OEM Volkswagen Sport Springs may be more akin to the Subaru BRZ, where the front spring rate is increased relative to rear spring rate -v- the standard GTI springs. This improves the low speed compression – secondary ride - as noted by racer Pobst. It also creates a greater amount of understeer and driver effort on corner entry, but better traction around apex and on exit of the corners, as was the case with the BRZ -v- FT86, with FT86 loser in the rear end on corner entry (soft front springs ... a bit like adding a rear sway bar only to the Golf GTI). This is probably more important at higher speeds in the fwd Golf as you need to keep all that front end mass (about 63%) under control, hence the higher relative front spring rates of the aftermarket Driver Gear Volkswagen Sport Springs in my GTI making it feel more BRZ like.
Once a decision is made on which is the better steerer ... BRZ or FT86 ... a comparison could be made with the MK7 Golf GTI further down the track to see if Volkswagen has something that is able to come remotely close to the twins for driver appeal.
How does this relate to the Golf R ... remember that the Driver Gear Sport Springs on my GTI have brought the handling closer to that of the Golf R, with higher speed alacrity, but less adjustable at lower speeds and improved secondary low speed compression ride comfort.
Cheers.
WJ
