Page 163 of 291 FirstFirst ... 63113153161162163164165173213263 ... LastLast
Results 1,621 to 1,630 of 2906
Thread: Golf R -v- Golf GTI
  1. #1621
    Apr 2010
    Melbourne, Australia
    Quote Originally Posted by Whistler View Post
    Now, back to the original thread...GTIs are for girls. Ha ha
    Go figure.
    And R's are for real men. That rules out dave_r
  2. #1622
    Sydney North
    Hi WJ and other members,
    I have been reading a lot of your posts about the R and the small and large sway bar set up. On the h&r site they list the the set up for the R as 26 rear 24 front not 26/22 or 28/24-in your opinion is their recommendation the right way to go? I am running Ku36 tyres.
    Also I am possibly looking at some H&R springs for the r, about a 20mm drop, do you think the H&r springs (stock shocks)with the front and rear sways will improve handling perfrmance somewhat? I am guessing the sways will be doing most of the work. I am looking at coils but for later on.
    Another option would be koni sport shocks with the H&R springs and sways. I am aware the the ride will be less comfortable but I'm interested in your opinion on the shock/spring set up as no one seems to be going this route with all going coils.
    Thanks heaps!
    Quote Originally Posted by WhiteJames View Post
    See that Golf R body roll in the pics from drive.com.au. The extra 130kgs being tossed around. The drive.com.au article is in direct contrast to earlier themotorreport.com.au article I posted. I’m siding with drive.com.au article re: Golf R as their observations are akin my views of the Golf R.
    Volkswagen Golf R review | hot-hatches
    Type & Size of H&R sway bars: Depends on your aims in suspension tuning.
    I’d highly recommend the small set of H&R sway bars for a daily driver, esp. on stock Golf R suspension with or without DCC. Set the front on soft and rear on hard.
    I prefer the comfort/sport tune with a near neutral - slightly understeer bias for a daily driven street vehicle. The stock Golf R suspension is very similar to the HPA Motorsport KW SHS re: sports/comfort kit, so no change needed on damper rates in this regard imo. The Golf R has a nice GT type of suspension tune without or without DCC.
    Small sway bars allow the standard street tyres to work with greater effect on public roadways where grip is limited. Large bars may quickly find the limitations of the street tyres, so an upgrade to semi-slicks maybe required due to the extra rigidity introduced into the chassis in terms of less suspension compliance that aftermarket sway bars offer. Suspension compliance is very important for a street car due to the variety of roadways conditions & gradients being encountered.
    If I was running a Golf R, my main aim would be to keep as much as the Golf’s independence in the independence suspension and only tune out some of that push understeer. Others may be looking to run semi slicks & coilovers for best times on the track, targa, or hill climb. In this case you’d want sports coilovers and large sway bars and probably stiffer suspension bushes & engine mounts.
    For predominately street driving, small matched set of H&R bars are more than enough for the daily grind as they really tighten up the chassis and cause a notable reduction in independence of one wheel bumps & gradients. The standard ride height of the Golf R is perfect imo.
    The H&R adjustable solid sway bars come in a matched set: Small 26mm/22mm and Large 28mm/24mm. You can mix and match (26mm/24mm, etc) – although I’d be inclined to stick to the small size matched set for public roadways and run the front on soft setting and rear on hard setting for a near neutral chassis tune.
    H&R do testing on places such as Nurburgring and Hockenheim with drivers that have much more experience than your average punter when it comes to chassis tuning. H&R recommend them as a matched pair or either small or large for best results with adjustments from hard to soft making a very notable difference to chassis tune.
    If I was going further in terms of a sporty suspension tune for a daily driver – I’d opt for, in addition to the small H&R bars a set of sports coilovers and rebranded KW V1 coilovers or if on a budget – the ST coilovers from HPA Motorsport for @ $800 USD - otherwise KW V1, KW V2 or V3. I like H&R sway bars as they have Teflon coated bushes that do not make noise, never need oiling and offer a great balance for all types of roadways. I also like the KW kits as they are similar to Koni in their valving & operation and also offer great NVH (no spring bind, tug’n’release or lack of spring rebound clonk in the coilovers).
    WJ
  3. #1623
    Feb 2010
    H&R made an error in recording the sway bar sizes for the Golf R on their website. H&R only offer the 24mm/26mm solid adjustable sway bars for the Golf R as is the case with the Golf R32 (Audi S3 too apparently). The H&R bars should do the trick for mostly dry conditions. After driving the Golf R for a bit around Eastern Creek Raceway in wet conditions, probably no need for the H&R bars in wet conditions (true for most makes of vehicles in the wet and the chassis becomes a little too rigid & offering less body roll). The H&R strut style sports spring & Koni strut damper will be an improvement in handling over the stock OE Golf R, but ride will suffer. The strut style springs with sports dampers tend to be over damped in the low speed compression, okay in the mid section bumps, but may spring bind for larger high speed comrpession bumps and may also tug'n'release at low car park speeds - they also offer varied spring rate when leaning into a corner, taking a bit away from overall control, but adding some fun at public road speeds. Coilovers are a much better alternative. KW would be my first pick or ST coilovers. Erik @ EVL Motorsport has corrected me in that the ST coilovers (like Weitec) are made in Germany, but are tuned for the American market, so may be a tad softer and higher than the KW Variant Coilovers. I stand corrected on two fronts. ST coilovers are also much cheaper than the KW V1 c/o kits. The KW DDC for Dynamic Chassis Control retail for about $3580 from EVL Motorsport if your R has DCC suspension. Edit: Robbie Jai has the H&R Sports Spring and Koni Sports strut dampers on his previous Golf R32 - he went with Bilstein PSS10 coilovers for his Audi S3 - may pay to send him a PM for his views on each setup.
    WJ
  4. #1624
    May 2010
    vic
    I drove R the other day after GTI and it does grip heaps better around the corners it felt as grippy as WRX. But somehow, strangely, it didn't 'feel' heaps faster then GTI in a straight line acceleration.
  5. #1625
    Nov 2009
    Hills District, Sydney, NSW
    Quote Originally Posted by mebius9 View Post
    That is the funny thing with the R is is deceivingly fast not obvious.. also I would hazard a guess the brakes were about 100 times better.. I hate the GTI brakes
  6. #1626
    Jun 2011
    Penrith, NSW
    Quote Originally Posted by SilvrFoxX View Post
    Will totally agree with you on this point SilvrFoxx. Constantly being caught out by the "deceptive" speed of the R, makes me love the brakes all the more
  7. #1627
    Mar 2010
    Motor or Wheels had a performance test in one of the issues and the GTI pulled up faster than the R in a 100-0 braking test. The stopping distance was shorter too.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  8. #1628
    May 2010
    vic
    Quote Originally Posted by GplusH_R View Post
    I was hoping R to be more ballistic like WRX or characterful instead of being a GTI+ if you know what I mean...
  9. #1629
    Nov 2009
    Quote Originally Posted by MkVIGTI View Post
    heh I wasn't talking about a measure up I was talking abut application..
  10. #1630
    May 2009
    Were you driving a tuned R or a stock one?
