Page 145 of 291 FirstFirst ... 4595135143144145146147155195245 ... LastLast
Results 1,441 to 1,450 of 2906
Thread: Golf R -v- Golf GTI
  1. #1441
    Nov 2009
    Quote Originally Posted by triode12 View Post
    You should consider adding the Unibrace X and Under bracing to the car. I can't vouch for the x brace, but the underbrace alone did stiffen up my car quite a bit. I would imagine the xbrace would do more.
    Fab_R has one on his R as well, and rates it. Damn they look good! The extra bracing would be great, but that look is a real bonus!
  2. #1442
    Aug 2009
    Melbourne - West
    I checkout the quality of others over several dealerships, and the water marks/spotting was evident on all of them.
    Serious! Damn thats pretty crap, my bro has a 182 and it has been great... most envolving drive to, heaps of fun.
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
  3. #1443
    May 2009
    Quote Originally Posted by AdamD View Post
    They are indeed very well made and finished. The quality is first rate - they are worth the $$.
    I didn't think that a MkVI owner would see much improvement with the Underbrace as I felt the MkVI to have greater lateral stiffness (when I tested them) over the MkV - which I thought was one of the improvements I could actually feel over the MkV. But I suppose I am wrong.
  4. #1444
    Nov 2009
    I don't have any issues day-to-day with the stiffness in the chassis, but of course there's no denying it's not race car solid. I do recall reading somewhere that VW had put some effort into increasing tortional rigidity in the platform for the MkVI refresh, but can't recall where I saw that, so it's just heresay.
  5. #1445
    Aug 2009
    Melbourne - West
    Jesus! That should do the job alright
  6. #1446
    May 2009
    Quote Originally Posted by adzy View Post
    Get both.
    UNIbrace.com
    However, the XB needs to have two holes drilled into the chassis - just behind the rear seats.
    While the UB uses existing bolts and holes.
  7. #1447
    Aug 2009
    Melbourne - West
    Get both.
    UNIbrace.com
    Just by looking at the design it seems as though the underbody would suffice as the flex I notice most seems to be more central than rear of the car, better wait for my other packages to arrive first
  8. #1448
    Aug 2009
    Melbourne - West
    ....... more so loss of luggage space when seats are down though.
  9. #1449
    Feb 2010
    Which has a stiffer chassis? Golf GTI or Golf R? Both the same imo. Golf R has a shallower boot, that may have some bearing on torsional rigidity. Ray's MKV R32 and my old MKV GTI, both with H&R sway bars f & r, exhibited the flex in the rear to about the same degree. Likely to be the same case with the Mark 6 GTI and R. Apparently the floor-plan on the Mark 6 has been strengthened, which includes rear end collision impact stiffness, so I'm told. The Mark 6 Golf GTI has a larger rear sway bar (24mm) over the MKV Golf GTI (22mm), which should in practice cause more noise when on a lateral slope. In addition to being a hatchback with some loss of rigidity over a sedan version with a boot there is nothing to compartmentalise the noises in the boot of a hatchback as in the case of the sedan. Interesting to see how much stiffer & wider the Mark 7 Golf/Audi A3 will be. The plastics in the Mark 6 make more noise than the plastics in the MKV imo.
    WJ
  10. #1450
    Feb 2009
    Sydney, Australia
    Get both.
    UNIbrace.com
    Fab_R has the UNIbrace UB on his car...
