The Wavetrac is unbelievable, simply trasforms the car as far as mid and corner exit behaviour goes... The car pulls in tight and just catapults the car forward... you should have a drive..
The HPA SHS have me confused.... They are a bit under sprung/damped for the track. On the street the ride is firm, a little choppy on Sydney roads, sort of bouncey.... they are adjusted within the specified height tolerances... i also find the shocks noisy once cold.... not as good as the V3's on Dads R32... Alot of the noise could also be due to the Whiteline antilift kit which i think has to go... too much NVH...
The H&R bars are better than the whiteline ones i had installed before, i think i'll set the rear to firm next time i hit the track.
Next step is a set of linear rate springs to go with the KW camber tops i have waiting to install.
