See that Golf R body roll in the pics from drive.com.au. The extra 130kgs being tossed around. The drive.com.au article is in direct contrast to earlier themotorreport.com.au article I posted. I’m siding with drive.com.au article re: Golf R as their observations are akin my views of the Golf R.
Volkswagen Golf R review | hot-hatches
Type & Size of H&R sway bars: Depends on your aims in suspension tuning.The single suspension tune still delivers the most supple ride here. And while there's an inevitable trade-off at the track, where the R feels noticeably softer than its rivals, the Golf is far from out of its league.It's just a case of the R's dynamics being capable of reaching the finals, rather than it being a genuine contender for the minor premiership. It's the first to wilt under the pressure of a flat-out track attack - the first to push wide (understeer) in corners when toying with these cars' limits. The R has enough steering precision and throttle adjustability to keep most drivers interested, though.It's a similar story on the road, even if a bonus for R drivers is that, while the steering lacks feel, there is none of the STI's nasty kickback or the RS's mild torque steer.
I’d highly recommend the small set of H&R sway bars for a daily driver, esp. on stock Golf R suspension with or without DCC. Set the front on soft and rear on hard.
I prefer the comfort/sport tune with a near neutral - slightly understeer bias for a daily driven street vehicle. The stock Golf R suspension is very similar to the HPA Motorsport KW SHS re: sports/comfort kit, so no change needed on damper rates in this regard imo. The Golf R has a nice GT type of suspension tune without or without DCC.
Small sway bars allow the standard street tyres to work with greater effect on public roadways where grip is limited. Large bars may quickly find the limitations of the street tyres, so an upgrade to semi-slicks maybe required due to the extra rigidity introduced into the chassis in terms of less suspension compliance that aftermarket sway bars offer. Suspension compliance is very important for a street car due to the variety of roadways conditions & gradients being encountered.
If I was running a Golf R, my main aim would be to keep as much as the Golf’s independence in the independence suspension and only tune out some of that push understeer. Others may be looking to run semi slicks & coilovers for best times on the track, targa, or hill climb. In this case you’d want sports coilovers and large sway bars and probably stiffer suspension bushes & engine mounts.
For predominately street driving, small matched set of H&R bars are more than enough for the daily grind as they really tighten up the chassis and cause a notable reduction in independence of one wheel bumps & gradients. The standard ride height of the Golf R is perfect imo.
The H&R adjustable solid sway bars come in a matched set: Small 26mm/22mm and Large 28mm/24mm. You can mix and match (26mm/24mm, etc) – although I’d be inclined to stick to the small size matched set for public roadways and run the front on soft setting and rear on hard setting for a near neutral chassis tune.
H&R do testing on places such as Nurburgring and Hockenheim with drivers that have much more experience than your average punter when it comes to chassis tuning. H&R recommend them as a matched pair or either small or large for best results with adjustments from hard to soft making a very notable difference to chassis tune.
If I was going further in terms of a sporty suspension tune for a daily driver – I’d opt for, in addition to the small H&R bars a set of sports coilovers and rebranded KW V1 coilovers or if on a budget – the ST coilovers from HPA Motorsport for @ $800 USD - otherwise KW V1, KW V2 or V3. I like H&R sway bars as they have Teflon coated bushes that do not make noise, never need oiling and offer a great balance for all types of roadways. I also like the KW kits as they are similar to Koni in their valving & operation and also offer great NVH (no spring bind, tug’n’release or lack of spring rebound clonk in the coilovers).
WJ
