Page 111 of 291 FirstFirst ... 1161101109110111112113121161211 ... LastLast
Results 1,101 to 1,110 of 2906
Thread: Golf R -v- Golf GTI
  1. #1101
    Mar 2010
    Quote Originally Posted by triode12 View Post
    That GTI Man 0-100 of 6.9secs must be a misprint. The old MKV GTI Man did 0-100 in 7.2secs. Surely, the DSG in the MKVI is as good as the old one and shifts faster than the manual.
    No it's not a misprint. VW claimed that the new Mk VI GTI manual has improved from 7.2 to 6.9 seconds in the 0-100km/h dash, while the DSG remain unchanged.
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
  2. #1102
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by Mountainman View Post
    Manufacturers' 0-100 claims =
    Golf GTI man 6.9secs
    Golf GTI DSG 6.9secs
    Golf R man 5.9secs
    Golf R DSG 5.7secs
    Doesn't seem much of an advantage.
    Subaru WRX 5.3secs
    Subaru STI 4.9secs
    Now that's an advantage when judged by acceleration alone.
    But how can you say VW manuals suck? I didn't think critical remarks like that were allowed on this forum. I thought they now have a reputation of some of the best manual changes around.
    I can say that they suck because that's my opinion, and because none of the magazines can actually replicate the claimed manual times, as your post to which I replied also displayed (6.63 sec tested vs 5.9 sec claimed). Whereas the claimed DSG times are regularly matched or even beat in magazine tests.
    Try and stick with the one type of data for your arguments. First you use magazine test times to prove your point, then when I point out that you've forgotten about the DSG, you switch to manufacturer claims to try to disprove me...
  3. #1103
    Feb 2009
    so what yields the fastest times, LC and sports mode, or manual shifting?
  4. #1104
    Dec 2009
    How does LC work in the DSG GTI?
    And I think Sport mode would be quicker than manual shifting Greg.
    2019 BMW M3 CS
  5. #1105
    Nov 2010
    Earth
    Whilst there is no doubt that the DSG version of the R is quicker off the mark, I'd be very interested in seeing a back to back around a track between a manual and a DSG. I doubt there would be much in it. My understanding (happy to be corrected) is that you can't effectively left foot brake in a DSG equipped car so you can't use that as a technique to keep the motor on boost whilst braking. Does the manual behave the same way?
  6. #1106
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by bcm View Post
    Yes, I'd like to see this too. I'm not sure if there has been any valid tests of two equally equipped Golf R's (apart from the manual and DSG) tested side by side on the one day.
    However, you can left foot brake if you want. The left foot braking "issue" is around the fact that Volkswagens have a "brake override" which overrides the accelerator in the case where the foot is on the brake. This is present in both the DSG and manual cars though. However, it has been tested that the brake override doesn't affect your ability to left foot brake in the context of track driving (and several other tasks that require it... there was a link somewhere on these forums, but I don't have the time to look sorry)
  7. #1107
    Nov 2010
    Earth
    So you can brake and have your foot into the accelerator and it doesn't cut engine revs?
    Or are you saying you can left foot brake, but that the application of the brake over rides the accelerator and the engine revs drop as a result?
    I'd look for the link but I'm lazy
  8. #1108
    Feb 2009
    Sydney, Australia
    Obviously when you put your foot on the brake, it'll slow you down, and if its in gear, you'll start dropping revs (all cars since beginning of time are like that if their brakes are working! auto/dsg/manual, doesn't matter).
    But with any modern car with a "Brake override", when the foot is on the brake for too long, the accelerator input will be ignored. This is for safety reasons, and will probably be mandatory for all cars within a few years (if the NHTSA and EU have their ways). But as was tested by the magazine (as per that link), the brake override in the cars that they tested still lets you have your "fun" (i.e. it didn't cut in when they were doing heal/toe, or the other things that they tried)
  9. #1109
    Dec 2010
    NSW
    Kinda off topic, but will have to do until someone can post an R DSG vs manual track test
  10. #1110
    Nov 2010
    Earth
    You are of course correct. What I should have said is can you keep the engine under load using the throttle and the brake together in order to keep the car on boost as you're braking. I'm still not sure. I've read you can heel and toe in the manual, but that's a very short duration using both inputs together. Everything I've been able to find so far (haven't searched for you link yet) suggests that the throttle body would close after a couple seconds on the brakes irrespective of what you're doing with the throttle.
    In any case it sounds like the DSG and the manual work the same way. Very different philosophy to an Evo.
