Page 73 of 291 FirstFirst ... 2363717273747583123173 ... LastLast
Results 721 to 730 of 2906
Thread: Golf R -v- Golf GTI
  1. #721
    Feb 2009
    Quote Originally Posted by Danny View Post
    Hehehe blame Volksy For that. We're in HERE b!tchin' because most of us are waiting for our golfs that are still out THERE
    LOL I feel your pain.
  2. #722
    May 2009
    Quote Originally Posted by Corey_R View Post
    Driving a current MKIV Polo GTI (ok, so it has stage I), I can say that it's a bit more "fun" than the MKV GTI was (before getting Stage II), but mainly because it's more raw and feels a bit faster - not because it actually has better abilities or anything.
    I've also driven the new MKV Polo 77TSI and I agree with dave-'s comments - it's very chuckable and quite zippy, and plenty of room if you don't need to put an entire family in there. I can only imagine one with twice the power (i.e. the GTI) would be quite amusing
    Changing your opinion Corey?! It wasn't too long ago you had a different view of things.
    The GTI mk1 had only 81 kw from memory not that much different from a 77TSI Polo (and it weighed less too). One thing we forget about the GTI is that it wasn't first about performance, it was more about fun.
  3. #723
    May 2009
    Quote Originally Posted by hooba View Post
    Great idea, and while you're at it, you should buy a itzy bitzy dog to match the Polo lifestyle.
    You seem to come out with these gems I assume is in defense of the Golf GTI, everytime I post something critical of it. Do you own a mkVI Golf GTI hooba?
  4. #724
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by triode12 View Post
    About what?
  5. #725
    May 2009
    About what?
    The Polo GTI (previous version) being more fun to drive than the Golf GTI (mkV). I think we had a differing opinions about this a while back IIRC.
  6. #726
    Feb 2009
    Sydney, Australia
    Well, I did say that it has to be a modified polo gti vs a standard golf gti
    Also note the use of "fun" vs fun
  7. #727
    May 2009
  8. #728
    Feb 2010
    Ray 'The Lurker' Thoughts on the Golf R
    After having my weekly coffee with neighbour Ray – Ray tells a bit more about his thoughts on the new Golf R:
    Ray says that if he had not been an owner of a Mark 5 Golf R32 – he would jump right into a Golf R without reservation. Being an owner of an R32 makes his purchase decision complex. The Golf R motor feels more powerful, faster & smoother in the way it delivers its herbs, and offers crisper throttle inputs in contrast to the older R32 that seems rougher & coarser in power delivery.
    Handling: The Golf R in DCC - SPORT mode felt to have improved damping over his R32, but exhibited more roll around corners and felt softer overall with the chassis leaning to a greater degree in corners. Ray’s older R32 showed to be bouncy over bumps with less compression & rebound damping, but sat flatter in corners with a tighter chassis offering a more direct connection from driver to vehicle when changing direction.
    Ray says that understeer between the Golf R and R32 was neither here or there around the tight twisties. The Golf R dampers in SPORT mode did reduce body roll; but aftermarket sway bars are generally the best item for reducing body roll at the expense of reducing the independence of each wheel – so it was understandable that Ray come to this conclusion that his R32 felt stiffer than the Golf R when leaning into corners.
    Ray preferred the turbo power delivery of the Golf R, but the handling of his R32, which also has an aftermarket Haldex Controller in addition to aftermarket H&R sway bars with front set on soft and rear set on hard to dial out as much understeer as possible. Ray didn’t notice to any great degree the improved weight distribution & absence of 35kgs up front in the Golf R on the slower speed tight 2nd and 3rd gear corners in comparison to his Golf R32. Much of a muchness he says, although the route comprised mainly of slow speed corners.
    Ray has looked at the Audi’s and discarded them on the value proposition. The new GTI is a distant proposition, mainly because it’s a different drive to both the R32 and Golf R.
    Next test drive on the cards for neighbour Ray is the new HSV Clubsport Commodore. Perhaps a Black HSV Clubsport with only about a 1-2 month delay from order to delivery if not already in stock, as opposed to the 6-8 month delay on the Golf’s.
    WJ
  9. #729
    Feb 2009
    How much fun do you want anyway, I can think of other things to do. The truth is you get used to whatever car anyway, but a few mods make the car more fun.
  10. #730
    May 2009
    Quote Originally Posted by G-rig View Post
    If you can get used to any car that is inherently fun, modding it will not help because you will get used to it after a while of owning it post mods. Then you will have to mod it some more and the cycle repeats itself.
    You better hope you don't feel the same way with your gf/spouse, she probably won't take it lightly.
