Page 27 of 291 FirstFirst ... 1725262728293777127 ... LastLast
Results 261 to 270 of 2906
Thread: Golf R -v- Golf GTI
  1. #261
    Nov 2009
    Ok you win, the R is better blah blah blah. But hey its gonna cost me crap loads to make the switch probably double the cost of what I could get for the R32 privately. You can't give away 2nd hand cars at the moment. And VW would offer me 2 and 6pence for the R32. Might just stick with it and keep giving my biased uneducated opinions to justify my position
    WJ - would you recommenmd H&R over whiteline for sways?
    Volvo S60 RD T6
  2. #262
    Feb 2010
    H&R sway bars are best by far and worth twice the price they may cost over the Whiteline bars. No need for new bolts or clips - H&R use OE bolts and clips for bushes. The bushes are rubber with a teflon coating that do not squeak and do not require any oiling. Front and Rear H&R sway bars on the R32 will bring the handling much closer to a new (stock) Golf R. Coupled with that super-responsive no-lag V6 ... the R32 will be formidable up a mountain pass.
    Cheers.
    WJ
  3. #263
    Mar 2010
    Witness Protection
    Quote Originally Posted by thezoneR32 View Post
    Brilliant!
  4. #264
    Feb 2009
    Nothing wrong with the handling of the R32 once you have some good Coilovers, Haldex Gen II and H&R sway bars. Would out handle an R on stock suspension IMO and then it's just down to your tyres which are the last thing to let go .
  5. #265
    Mar 2010
    Lost
    Is this thread still going????
    More opportunites have been lost from indecision, rather than wrong decision....
  6. #266
    May 2010
    Yep? This message is too short?
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  7. #267
    Nov 2009
    Quote Originally Posted by entice View Post
    Why wouldn't it be, this thread is like politics or religion. No one will ever agree but this *is* a discussion forum is it not?
  8. #268
    Feb 2010
    Go Auto review from the Tasmania Golf R launch drive:
    Volkswagen Golf R 3-dr hatch | GoAuto - Our Opinion
    Interesting to see that the Manual Golf R has shorter gearing than the DSG Golf R.
    Cheers.
    WJ
  9. #269
    May 2010
    I would have thought the opposite? Interesting.
  10. #270
    Feb 2010
    EA888 -v- EA113
    Service Training
    Self-Study Program 824803
    The Volkswagen 2.0 Litre
    Chain-Driven TSI Engine
    EA888: High-Pressure Pump
    The demand controlled high-pressure pump by
    Bosch is driven by a four lobed cam on the end of
    the intake camshaft.
    The pump piston is driven by the camshaft and a
    cam follower. This reduces friction as well as the
    chain forces. The results are smoother engine
    operation and higher fuel economy.
    The use of the four lobe cam has allowed a reduced
    piston stroke compared to earlier versions of the
    2.0L TSI engine. Due to the shorter stroke, the
    individual delivery rates are lower. This, in turn,
    results in reduced pressure fluctuations. The
    metering precision of the injectors is also improved,
    as there is now one feed stroke per injection. The
    advantage of this is improved oxygen sensor control
    and fuel efficiency.
    EA888: Fuel Rail
    The fuel delivery rate of the high-pressure pump has
    been reduced through the use of a four-lobe cam.
    A quicker pressure build-up is thus possible. This
    build-up benefits both cold start and hot start
    situations.
    The EA888 motor in the Mark 6 Golf GTI (and Tiguan 125TSI) has improved fuel metering over the older type EA113 motor in the MKV GTI and Golf R. The reduced fuel pressure fluctuations of one feed stroke per injection of fuel in the new EA888 motor results in greater consistency between the throttle application and acceleration of the motor – in other words - the injectors and fuel pump are working in unison on the same time cycle in the new EA888 motor.
    Turbo lag down low on the Golf R was not the only issue I found with the KO4 boosted older EA113 motor. The pressure fluctuations between throttle applications and lack of motor response, or at times, too much motor response, was noted on my Golf R test drive and it detracts from the driver/vehicle feeling of connectedness.
    Volkswagen has done a sterling job of reducing the turbo lag in the KO4 Golf R EA113 motor. The difference in fuel pressure build-up between the older EA113 motor and new EA888 motor feels tangible, as mentioned by myself in post # 1-2 and other forum members in subsequent reviews. Other forum member’s reviews described the throttle response of the Golf R as ‘wooden’, ‘unresponsive’ or ‘inert’.
    The same also holds true between EA113 and EA888 of the MKV and MKVI Golf GTI motors using a similar sized turbo-chargers (also holds true for the Audi A3 147 kW Quattro AWD –v- Tiguan 125TSI AWD). Turbo lag of the larger KO4 turbo is another issue in itself.
    There was a stage a several years ago where guys that boosted their turbo-chargers on the EA113 MKV GTI motor experienced fuel delivery problems esp. when going to stage II turbo boosted tunes – this came down to issues with the OE fuel pump and absence of the four lobe cam actuator in the older MKV Golf EA113 motor.
    WJ
