The Pirelli's rims were 18" x 7.5" - therefore they didn't require the wing extensions.
The optional 18" wheels on the regular MKV GTI, which were hardly EVER optioned, were the Karthoums, as G-rig mentioned. These were 18" x 8" and required the wing extensions.
It should also be noted that the 18" Talladega wheels on the R are also 7.5" wide. It's only when you move to the 19" Talladega that the width increases to 8" and these additional pieces that shakespeare has pictured appear. Remember (I'm sure you know, but others might not realise) that moving from 17 to 18 to 19" wheels should result in the same rolling circumference and therefore not affect ride height or cause things like rubbing. It's the changes in width and offset that cause rubbing.
Hmm not sure! Both? What I did notice is that they "wing extension/protectors are only placed on the join where the front/rear bar meets the body, and as coreying has mentioned the 19" are 235's on 8" wide rims which mean wider, would be interesting to see if the offset is different to the 18" and what if any track differences there are between the two.
I got the 19" as I like the black surrounds and the look of the 19's too![]()
WLF127
There are lots of pictures of the cars with the black headlight surrounds though. Basically any car after the initial press-release photos will have them. Like the show car at the Frankfurt Motor Show....
Edit... but yeah, I'd love to fly to Germany and follow my car through the production line. That'd be awesome![]()
Doneloads of pics here (apologies for OT)
Volkswagen Golf R (2010) with pictures and wallpapers
WLF127
I don't mind either black or silver.. Silver looks more expensive and shows off the bi-xenons for what they are, black is a bit more hidden, looks a bit cheaper but more aggressive.
The wing extensions are required for any 8" wide rims on the golfs (7.5" is standard) for ADR compliance at time of sale.
Once you have bought the car, there is only a couple of screws holding them on so they don't need to stay on there.
