Results 1 to 3 of 3
Thread: Rough idle / stuttering acceleration
    Oct 2013
    Harrington Park, NSW
    Hey guys,
    I've recently bought a manual, 60 000km, 2010 Mk6 GTI. I noticed straight away that the acceleration had some stuttering in the low revs and also that it has been idling rough and popping occasionally on a cold start. When she settles under 1k rpm after a minute or so, seems fine. I've brought the car to VW to diagnose under dealer used car warranty and they've located a misfire and remedied the issue by cleaning and re-spacing the spark plugs. I feel as if the low rev acceleration in first has definitely improved, though other gears still don't feel as smooth or linear in acceleration.
    Similar to Faint "miss" at idle?, but with the acceleration problem. Anyone ever had a similar issue or ideas on what else I could have them look for?
    Cheers.
    Jun 2011
    Caroline Springs, VIC
    Do you know if they inspected the coil packs?
    Jul 2012
    Sinagra, Western Australia
    Could be related to oil consumption(fouling plugs) or a leaking injector. Out of those 2 however the cleaning/regapping plugs would only have fixed a fouled plug... Temporarily.
    If you have a vagcom, take a drive a monitor MVBs 15 & 16 in the engine to see which cylinders are registering a misfire.
