Thanks for the advice Triode.
I enjoy driving my cars every time I jump in them, not sitting on here trying to.be a prick.
I've a suggestion WJ. Does Ray still have the OEM parts for the R32?
Why doesn't he put back the OEM suspension, remove the Haldex controller, and then install them on the R?
I know that the haldex is newer in the R, but maybe the aftermarket controller can be upgraded or traded in for the latest version?
We've already established that the MK6 chassis is tighter than the MKV's. The haldex controller will also make a good difference. I'm sure that modified, the R will simply kill the R32 due to the reduction in weight, better haldex, and better chassis.
I gotta ask, does Ray exist or is this whole thread about your imaginary friend? If it is the latter, then that's an awesome effort to reach 37 pages
Not true IMO. If you buy a dud and you're stuck with it, you'll hate it. I loathed the 18mths I was stuck with my last XR6T due to it being a 2yr lease!
ROFL
Ray does exist ... lol. Here is a pic of his ride. Find the H&R and Haldex stickers and there's $5 in it for you.
Suspension Review: KW V3 -v- Neuspeed Sports/Koni FSD - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
Ray will sell his R32 with H&R bars and Haldex installed. I know he has discarded the sway bars - they are with East Coast Suspensions, Taren Point. Not sure about the Haldex controller. Ray's R32 may be up for sale in the near future at the Prestige Auctions in Sydney - Nov 07 build with only 30,000km on the odo. Tried to talk him into putting a Supercharger in the R32, but it's time for a change he says.
The Haldex in the Golf R is much better than the aftermarket Haldex for the R32. No need for the older Haldex unit.
H&R have released new versions of sway bars for the Golf R - they now come in large size and small size for the Golf R. Not sure if the older R32 H&R bars from the R32 will fit the Golf R.
After the Golf R drive, I think Ray is looking for something that drives a bit different. Golf R is fast and knowing Ray, he would probably go the whole Stage III hog on it, but it fails to excite him. His previous ride to the R32 was a Black Monaro that was HDT enhanced with 330kW motor, body kit & wheels, Harrop 7K BBK, short ratio LSD diff, racing clutch, and aftermarket suspension upgrade ... geniune 12 sec machine. He may revert back to Holden's HSV for a enhaned drive experience at the detriment of the el-cheapo interior. The HSV with LPG is pushing almost 2 tonne in weight.
WJ
As mentioned earlier:
After the short & sharp hill-climb RNP drive of the Golf GTI and Golf R, both with DCC (a must have on the GTI) - my values moved in favour of the GTI by 80% to 20% for the Golf R. Although it's worth mentioning that the short drive route would naturally favour a lighter & more agile vehicle.
In respect to the fuelling of the Golf R, it feels very much like the MKV GTI, rather than a beefed up version of the Mark 6 GTI. From Golf R to Golf GTI is like going from carburator to fuel injection or old style fuel injection that varies fuel metering every 500rpm as opposed to a modern fuel injection system that can vary fuel metering every 50rpm. This relates to engine feel/turbo responsiveness & general economy, rather than outright power (NSACAR's make heaps of power and run carbies) - Golf R and MKV GTI seem to be more one dimensinal in it's fuel delivery - which does feel more linear in delivery.
After visiting the Sydney Motor Show, my values have changed again:
Golf GTI: 50%
Polo GTI: 40%
Golf R : 10%
Polo is a bit cramped in the rear passenger seats and luggage compartment and I'm told it has torsen beam rear suspension (as does Civic Type R, Megane, Clio), as opposed to the GTI/R mutilink sub-frame rear suspension that should generally cope better on unsettling features around mid-corner. Mid corner bumps are in abundance in NSW so multilink rear suspension should prove it's worth in this regard. Torsen beam suspension imo is not fully independent suspension, but does add rigidity to the chassis. The Golf R at the AIMS wins my vote for best looking hatchback.
WJ
More on Polo GTI:
First drive: Volkswagen Polo GTI
Article sums up XDS in a nushell:
CheersIt works in conjunction with the car's traction control and electronic stability control program and together the system certainly helps but doesn't remove the need for a smart right foot.
WJ
Sorry, this thread is about Polos now?
