Parallels can be drawn here. Both Ford and Renault feature a pukka limited-slip differential and independent steering axis front suspension (called RevoKnuckle on the Focus, PerfoHub on the Mégane). The benefits of this are clear. In both cars you can get the power down early, feeling the front end earn its keep as it digs in and attempts to hold its line. The end result is the same – masses of speed and poise out the far side of any given corner.
But from the driving seat of each car the experience is very different. I’m leading in the Mégane, the Focus’s gaping grille hoovering up the road behind me, often lost in sheets of spray. The Renault suffers no torque steer, it just hooks up harmoniously and pulls; the balancing act between strut, steering and differential has been masterfully judged. The Focus is messier. It scrabbles a bit, the wheel tugs in your hands, but it’s eye-poppingly entertaining to hurl around.
I’m enjoying the Mégane’s steering more here than I did on the launch. It’s weightier than the RS’s and more positive on turn-in. And the Mégane’s engine is so responsive – it’s far less laggy than the Ford’s, but it’s also far less exciting to listen to than the trumpeting five- cylinder, which sounds better on the overrun than the Renault does at full chat.
Both cars have great brakes, bringing tangible benefits for those prepared to dabble with left-foot braking, and both make a mockery of conditions that are causing localised flooding nearby –
there really isn’t much else this side of a GT-R that I’d be more confident of driving faster right now.Chris and I stop to debate. Moral victory goes to the Mégane. It doesn’t set out to be as uncompromising as the Focus and yet it ends up being almost as entertaining. Almost. ‘It’s the first car to highlight weaknesses in the RS that previously we’ve waved aside,’ Chris says. ‘The skyscraper driving position, the light steering, the difficulty of heel-and-toeing, the slightly laggy and inconsistent power delivery.’ I find it more approachable at the limit, and love the way you can build up such a sinuous flow on good roads. It’s addictive.
The Ford bludgeons rather than caresses, but what makes it so absorbing and memorable is that it has such unbelievable attitude. It doesn’t try to be refined and so comes across as a purer, more concentrated machine. A hot hatch in bodystyle only, it successfully distances itself from a class that can be – as both SEAT and to a lesser extent VW prove – rather underwhelming.
