Page 584 of 651 FirstFirst ... 84484534574582583584585586594634 ... LastLast
Results 5,831 to 5,840 of 6510
Thread: Golf R Observations and Questions
  1. #5831
    No worries, just keep the FIS box in the little compartment under the light switch and then it's pretty easy to disconnect/bypass when needed. It's recommended to disconnect the relevant fuse (or battery) when doing it.
    Mine located directly in front of the gateway module itself so if I ever need to access the thing its only a matter of :
    remove wiper arms
    remove rubber strip off wiper motor/vent/ECU/soundaktor panel
    remove motor/vent panel
    remove engine bay firewall panel to wiper vent ECU area
    remove wiper motor contraption
    remove cover to access CAN gateway module
    Then when I'm finished I simply reverse the procedure
  2. #5832
    Apr 2010
    Go via the dashboard, I've done both methods and it's much easier (besides not being able to see what you're doing). Once you figure it out the first time though after that you'll be in there within a minute or two.
  3. #5833
    Actually it didn't take me more than 15 mins to install, I'm pretty good at ripping these things apart now and have all the nice tools that make it easier. Initially I went from underneath and there is no way I could get up there its at the highest point not sure if its the same as your ones location - pretty sure it would be
    OK I know we are taking the thread OT but you get that
  4. #5834
    Nov 2009
    Hills District, Sydney, NSW
    Is that paint work A) Whits B) Dirty
    That has taken the thread over the top as it looks like you are pulling an old fridge apart
  5. #5835
    Apr 2010
    Yep, same location for me. Just had to push the relays out of the way and then use a long flat screwdriver to pop the gateway up and then it was an easy grab.
  6. #5836
    Mar 2008
    Sunshine Coast
    Anyone noticed a slight clunk coming from the front suspension when going into reverse
    Not gearbox. Sounds like front right.
    Car goes in for service next week so will let them know but wondered if anyone else had heard this
    Bit early for LCA bushes ?
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  7. #5837
    Apr 2010
    I hear little clunks while reversing (when I press the gas pedal, esp when going uphill), am told it's nothing to worry about.
  8. #5838
    Mar 2008
    Sunshine Coast
    Are Redbook prices about right for the 2nd hand Golf R market at the moment ?
    Also, anyone that has sold one recently, much interest ?
  9. #5839
    Nov 2009
    Re: Golf R Observations and Questions
    Don't do it CM
  10. #5840
    Nov 2012
    QLD
    Quote Originally Posted by Candyman View Post
    I'll start the bidding at $25,000. Used car market is dead and yours is obviously a lemon...lol. Small amount to pay considering your problems become mine.
