Lol thought I did but I missed that part
No worries. Don't forget to read the manual while you've got it out![]()
My12 Golf R -DSG, sunroof, vienna leather interior
Visit my page - https://www.facebook.com/StreetwiseW...ledVolkswagens
https://www.facebook.com/Streetwiseaircooledvolkswagens
May have already been posted but Volkswagen Driver Jan 2013 issue has a special on the Golf R
Nothing major but some good reading
https://itunes.apple.com/au/app/volk...468631656?mt=8
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
Oh and those screenshots I posted are from the VW Golf R app (I got it a while back).
Don't bother getting it - pretty light on content.
Edit - oooops, think the screenshots were on the other forum
In the MFD I can't work out how to display the boost in PSI![]()
It's in the options, the one under Parameters iirc, where you can change all the units.
Yes there's an option to turn it off, then to turn it back on you have to hold the OK button for 30 seconds.
Yeah done all that but during the flashing process which is normally about 18 mins you don't want things to be interrupted at all and I need to make sure that its not just sitting there polling things while its turned off. The fact that it can be turned back on with the 30 second depress means to me that it it monitoring things in some way.
Its a good piece of gear though
No worries, just keep the FIS box in the little compartment under the light switch and then it's pretty easy to disconnect/bypass when needed. It's recommended to disconnect the relevant fuse (or battery) when doing it.
