Page 560 of 651 FirstFirst ... 60460510550558559560561562570610 ... LastLast
Results 5,591 to 5,600 of 6510
Thread: Golf R Observations and Questions
  1. #5591
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by seangti View Post
    EDIT: Just read up on those gauges. Seem to awesome pieces of kit.
    For $500, I believe everything it tells me!
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  2. #5592
    Apr 2010
    Check out the PolarFIS+ Advanced while you're at it - adds loads of ECU parameters (customisable) to your MFD for ~$300
    http://www.vwwatercooled.com.au/foru...tml#post883193
    Or if you're tight get Torque Pro for Android ($4), an OBD2 Bluetooth adapter ($15), Android phone (?) and phone holder ($20)
  3. #5593
    Jul 2012
    Gold Coast, Qld
    I've got an iPhone 5 and Harry's Laptimer Pro. Emprum UltiMate GPS on the way + Gopoint BT1 Bluetooth OBD. I'll be set!
  4. #5594
    Jan 2009
    Quote Originally Posted by Machine View Post
    That'll be the ducks nuts. Really looking forward to seeing all the data. So much data at your hands (said with a little envy of not having gone down that path myself). If my phone wasn't provided by work and I ran apple at home, it'd almost have been a sure thing.
    Daily: 2010 VW Jetta Highline
  5. #5595
    Jun 2011
    anyone installed one of these in an R? (assume same as the 118TSI, so in from the engine compartment?)
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
  6. #5596
    Nov 2009
    I've got one, but haven't installed it yet. Miro (Transporter) had a look at my GTI this morning and suspects it is actually possible to get to the CAN gateway and install it via the dashboard (from the compartment to the right of the driver's knee). Trouble is it's a little tight in there, and you'd need to disconnect/reconnect the leads with one hand. Still, worth considering as an alternative to going in underneath the wipers.
    I'll update when I get mine installed in a few weeks - if no-one else provides more info in the meantime.
  7. #5597
    Apr 2010
    Mine is currently in London Heathrow after leaving Spain yesterday...
  8. #5598
    Apr 2012
    Picked up my R a couple of days ago and very impressed with the car so far.
    Is it possible to turn off the Daytime Running Lights (DRLs) on the R? I cant find it in the MFD settings and this link I found doesn't work either:
    HOW TO: Turn the Daylight Running Lights (DRL's) on and off
    Is it possible through VAGCOM and has anyone successfully turned them off?
  9. #5599
    Nov 2009
    Hills District, Sydney, NSW
    I thought you could via the MFD.. but I like them so never looked
    How to disable the DRL daytime running lights on 2010 2011 VW Golf, GTI, Jetta, and sportwagen wagon
    If you want the VAGCOM way
  10. #5600
    Jul 2012
    Gold Coast, Qld
    You can't disable them through MFD or by any "normal" means. Turning the headlight switch to off keeps them on, so does Auto and On. Turning the switch to parking lights only dims them, while also turning on the rears.
