Page 550 of 651 FirstFirst ... 50450500540548549550551552560600650 ... LastLast
Results 5,491 to 5,500 of 6510
Thread: Golf R Observations and Questions
  1. #5491
    Apr 2012
    My R also has a pause sometimes which sounds exactly like what AdamD has suggested.
    Black MY12 Golf R DSG, Silver 19", Leather, Sunroof.
    Previous ride: MY03 Subaru WRX 161.9 kW
  2. #5492
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by Ideo View Post
    I thought selecting a lower gear was pretty easy and straightfoward.
    Clutch in. Move gearshift from fourth to third (other gears available). Clutch out.
    Easier still with DSG (and more fun), well, on mine
    I did have the mech replaced though
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  3. #5493
    WA
    Probably a silly question but, when in manual mode with the DSG, is it ok to let the gears change down by itself when approaching say a red light, or should you be changing down manually?
    MY13 Golf R Rising Blue ; DSG ; ACC ; Sunroof ; RVC ; 19" Black Talladegas
  4. #5494
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by bobdog View Post
    It's perfectly fine
    That's the flexibility the DSG offers
  5. #5495
    WA
    Thanks Candyman
  6. #5496
    Mar 2008
    Sunshine Coast
    Thanks Candyman
    Just be careful though
    Some people tend to forget they are in manual mode when they take off
    Likewise some who use manual a lot and use auto rarely go to change gear with the stick
    I've done it ! On my GTI though when I was getting used to DSG. Rather embarrassing
  7. #5497
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by AdamD View Post
    James is referring to the delay when selecting the next lower gear in manual mode, when the DSG has already preselected the next upper gear. There is a delay, it's unavoidable, and is present on every DSG I've driven for an extended period (and that'd be 6 or more).
    The DSG needs to anticipate the direction of change you intend to make, before you make it. Say you're in 4th and are decelerating (or even cruising), the alternate shaft may have 3rd preselected, and in those cases, you can instantly shift to 3rd (and as soon as you do, the DSG will anticipate the same situation will occur again and will preselect 2nd on the shaft that originally had 4th engaged, and so on, giving you seamless, fast downshifts).
    However, if you're accelerating in 4th (and the DSG has anticipated 5th will be required next and has preselected), and you then downshift whilst accelerating, the DSG will need to pause while the secondary shaft changes from 5th to 3rd. Sometimes you may even feel some hesitation in the power delivery when it finally does shift.
    I've seen exactly this behaviour from several VW DSGs, and am confident it's not related to any mechatronic fault.
    Good on you, AdamD.
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  8. #5498
    WA
    Quote Originally Posted by Candyman View Post
    Lol, I have done that a couple of times, but I quickly learn when I hear the engine
    Haven't drive a manual since I sold my 2002 325Ci, that was quite a nice car to drive
  9. #5499
    Mar 2008
    Sunshine Coast
    I drive a manual at weekends and sometimes during the week but always look forward to going back to the DSG, it is that much fun
    The R's DSG (well mine) is very well behaved compared to my MKV GTI I owned.
    Cleaner shifts, no hesitation, smooth in reverse and low speed.
  10. #5500
    Mar 2008
    Sunshine Coast
    Bob
    How are you finding the torque from the R versus the Beemer ?
    Should be close in terms of day to day driving but no doubt the Beemer has better response off the mark
