Don't pause between changes, totally messes with the mech unit logic.
Keep power on during changes, the next gear is already at the right speed ready for the change
Drive it like a manual. You might even go so far as pretending to depress a clutch pedal between finger flicks!
Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
I think we're talking about downshifting to accelerate, in which case it's a good idea to ease off the accelerator. Kind of like double-clutching in a manual.
Have driven the 26000 km with throttle on as required
Has never failed to pick up the necessary gear on the down change
Pretty much how I drove my GTI as well
The R is more forgiving than my GTI was in that regard (easing throttle on the change causing unsettling of the chassis)
My observation about the gear changes was more in the situation where you're driving down an urban road at 60kph in 3rd approaching a traffic light. If the light stays green you might change into 4th, but if the light changes you want to grab 2nd as you start braking. If the gear you pick is the one the DSG has pre-selected the shift is very quick, but if it's the 'wrong' gear you have to wait for a second or so for your request to be actioned.
In flowing / spirited driving the actions of the pedals seem to be a far better indicator to the DSG as to your intentions so it seems to get the correct gear pre-selected in those situations.
A few other observations from Day 2 with the car:
•The Bluetooth audio is fantastic. I discovered that I can jump in the car with my iPhone in my pocket, press Play on the touch screen and voila - music. This music / handsfree phone setup is by far the best of any car I've owned.
•After a Stage 1 flash this morning the car is certainly more responsive - probably more in keeping with what I'd expect it to have been from the factory. Big thanks to the CVWC guys - they did the stage 1 flash and the read cycle for the DSG upgrade while I waited and I was out the door in less than 30 minutes. The extra punch at the top end does make the DSG / low RPM 'lag' when moving off more noticeable though - I'm assuming the only way to get power right from a standstill is using the launch control which I haven't done yet.
Well in that case, you definitely want to ease off the throttle because you're decelerating. But in the former scenario, I guess it depends on whether you were doing a steady 60 or if you were accelerating or decelerating slightly at the moment you want to change gears. Might also depend on engine speed.
James
Regarding the gear changes, something isn't right mate with your DSG (infamous mech unit )
I can drop 2 or 3 gears with fast paddle flicks without any pause - same using the stick
Hopefully the DSG tune resolves that as it is abnormal
Regarding "lag" on takeoff after the tune, again, abnormal if it is worse than it was stock
The FBW does induce some "lag" but the tune should help deliver more response low end via timing.
Is this in D or manual mode ?
D can be sluggish off the mark
James is referring to the delay when selecting the next lower gear in manual mode, when the DSG has already preselected the next upper gear. There is a delay, it's unavoidable, and is present on every DSG I've driven for an extended period (and that'd be 6 or more).
The DSG needs to anticipate the direction of change you intend to make, before you make it. Say you're in 4th and are decelerating (or even cruising), the alternate shaft may have 3rd preselected, and in those cases, you can instantly shift to 3rd (and as soon as you do, the DSG will anticipate the same situation will occur again and will preselect 2nd on the shaft that originally had 4th engaged, and so on, giving you seamless, fast downshifts).
However, if you're accelerating in 4th (and the DSG has anticipated 5th will be required next and has preselected), and you then downshift whilst accelerating, the DSG will need to pause while the secondary shaft changes from 5th to 3rd. Sometimes you may even feel some hesitation in the power delivery when it finally does shift.
I've seen exactly this behaviour from several VW DSGs, and am confident it's not related to any mechatronic fault.
Sorry, I get no delay, none
I thought selecting a lower gear was pretty easy and straightfoward.
Clutch in. Move gearshift from fourth to third (other gears available). Clutch out.
Audi S3. Sold
Golf R. Sold
Citroen DS3 Dsport. Sold
2016 Skoda Octavia RS Wagon.
