In my GTI and the R they always go to the park mode when off but it is the passengers side that sits high
I wouldn't do that, notice that under some operation, the passenger one *does* tuck down there, it seems to have two positions it comes back to depending on ??. Have them running and you will see it will sweep to the high position, and then a second or two later, if it isn't wiping again, will drop it down into the lower spot. I dunno why though it decides to park them in the higher position more often than not... another VW mystery.
Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
That is what I am talking about. I mean in operation, they will go to the lower position, the passenger one seems to have 2 positions it goes to depending on goodness knows what. If you try to drop it lower, it will sweep onto the plastic cowl in some operation.
When I said higher position in my post before, I wasn't talking about up the windscreen (service mode), I was talking about the 2 positions it goes to in the lower arc... it has a higher one and a lower one and I don't really know why they bother?
Mmm, mine has never gone lower, on either car
Still has 2cm left in sweep
Meeting a couple of R owners this arvo - will see what they have noticed
Thanks for the info
The two park positions are to ensure the blades don't sit the same way each time
I was suggested that by Candyman moving them down by a few centimetres as they are dry parked, will cause then to hit when they do their funny extra pull down they do on the passenger side in normal operation.
They are already fully parked (as I mentioned). The passengers side has already done the final park and still is higher by 2 cm than the drivers side and still has room to go down further.
The "funny extra pull" is as we have all mentioned - that is the final position and is only a small movement down to move the blades to a different position each time.
I just assumed they pull down further when driving (when not in use) for better aerodynamics. When washing the car the left one is not quite all way down but to be honest I'm not bothered. Friends who think they're funny still can't raise the wipers up.![]()
Can't find it in the manual but how do you actually turn off air flow through the vents?
My12 Golf R -DSG, sunroof, vienna leather interior
Visit my page - https://www.facebook.com/StreetwiseW...ledVolkswagens
https://www.facebook.com/Streetwiseaircooledvolkswagens
