Page 493 of 651 FirstFirst ... 393443483491492493494495503543593 ... LastLast
Results 4,921 to 4,930 of 6510
Thread: Golf R Observations and Questions
  1. #4921
    Jan 2012
    Epping, NSW
    Quote Originally Posted by Candyman View Post
    Speaking of wiper arms, are they on a spline because I want to move the passengers side down an inch so it tucks under the bonnet more
    I wouldn't do that, notice that under some operation, the passenger one *does* tuck down there, it seems to have two positions it comes back to depending on ??. Have them running and you will see it will sweep to the high position, and then a second or two later, if it isn't wiping again, will drop it down into the lower spot. I dunno why though it decides to park them in the higher position more often than not... another VW mystery.
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
  2. #4922
    Mar 2008
    Sunshine Coast
    In my GTI and the R they always go to the park mode when off but it is the passengers side that sits high
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  3. #4923
    Jan 2012
    Epping, NSW
    That is what I am talking about. I mean in operation, they will go to the lower position, the passenger one seems to have 2 positions it goes to depending on goodness knows what. If you try to drop it lower, it will sweep onto the plastic cowl in some operation.
    When I said higher position in my post before, I wasn't talking about up the windscreen (service mode), I was talking about the 2 positions it goes to in the lower arc... it has a higher one and a lower one and I don't really know why they bother?
  4. #4924
    Mar 2008
    Sunshine Coast
    Mmm, mine has never gone lower, on either car
    Still has 2cm left in sweep
    Meeting a couple of R owners this arvo - will see what they have noticed
    Thanks for the info
    The two park positions are to ensure the blades don't sit the same way each time
  5. #4925
    Nov 2010
    Burpengary, Queensland
    Quote Originally Posted by tonymy01 View Post
    Not a mystery, but a pretty clever feature. It is so the rubber sits at a different angle/edge that is in contact with the screen, hard to explain but it is designed that way
    edit just realised I repeated what CM said above
  6. #4926
    Aug 2009
    Melbourne - West
    Its not the feature you are talking about which moves the wipers a half inch or so when you shut the car down depending on if you used them or not? It does this in order to not have the wiper blades worn or bent to the one side.
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
  7. #4927
    Jan 2012
    Epping, NSW
    I was suggested that by Candyman moving them down by a few centimetres as they are dry parked, will cause then to hit when they do their funny extra pull down they do on the passenger side in normal operation.
  8. #4928
    Mar 2008
    Sunshine Coast
    They are already fully parked (as I mentioned). The passengers side has already done the final park and still is higher by 2 cm than the drivers side and still has room to go down further.
    The "funny extra pull" is as we have all mentioned - that is the final position and is only a small movement down to move the blades to a different position each time.
  9. #4929
    Apr 2010
    I just assumed they pull down further when driving (when not in use) for better aerodynamics. When washing the car the left one is not quite all way down but to be honest I'm not bothered. Friends who think they're funny still can't raise the wipers up.
  10. #4930
    sydney
    Can't find it in the manual but how do you actually turn off air flow through the vents?
