Page 455 of 651 FirstFirst ... 355405445453454455456457465505555 ... LastLast
Results 4,541 to 4,550 of 6510
Thread: Golf R Observations and Questions
  1. #4541
    Apr 2010
    No probs - I tend to rarely push the pedal far down (unless the car isn't responding or changing down a gear) so I find it helps.
  2. #4542
    Apr 2010
    Melbourne, Australia
    tonymy01 - Sprintbooster will be the solution to your issues.
    2nd will be a tune.
    Ryan and I are massive advocates of the SB for a good reason. They work and work well!
  3. #4543
    Apr 2010
    For me it's all about making otherwise-boring trips quite a bit more fun
    That said I wish I knew what 0-100 in 3.95 seconds felt like
  4. #4544
    Apr 2010
    Spot on mate......
    You know im in Melb..... "come at me bro"
  5. #4545
    Apr 2010
    Well I do work in the CBD so I guess something should be arranged.
  6. #4546
    I think the the sprintbooster is a bit redundant if your tuning the car though, all or at least most of the crapness is removed in the process
  7. #4547
    Jul 2011
    Burwood, VIC
    Quote Originally Posted by parso_rex View Post
    well if you tuned it Parso then yes of course you'd modify the relevant table .. but I can confirm that for my remap, there is absolutely no change to the accelerator signal, and the stock Golf R desperately needs this.
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
  8. #4548
    Well I haven't bothered with the pedal and throttle plate position directly but we do bring in boost a fair bit earlier than most more torque etc, so it reduces the effect dramatically. I can see that the sprintbooster would effectively mask the issue on an otherwise stock setup as it moves the pedal position away from where the delay is experienced
  9. #4549
    sydney
    I know the DSG gearbox preselects the next gear when upshifting but how does it work downshifting? does it use the current clutch to downshift back?
  10. #4550
    Jul 2011
    Burwood, VIC
    Quote Originally Posted by Paulc1964au View Post
    one clutch is odd gears and the other is even.
