no its part of the original muffler. In between the two tailpipes theres a valve that opens and closes the drivers side exhaust pipe. The Valve has a vacuum line thats attached to the top of it similar in size to that which you would normally see used in wiper washer hoses. What some of the guys do is remove the rubber hose and block it with a screw or similar just to change the exhaust tone at idle.
Its worth checking to see if its been left off for some reason. I'll see if I have a picture somewhere.
---------- Post added at 01:17 PM ---------- Previous post was at 12:50 PM ----------
Here you go, these are truly crap pictures taken with the front camera of my iphone but you get the idea. That black solenoid has the black vacuum hose entering at the top which in effect is the side of the black body if you had the valve off the car - if that makes sense. You should be able to feel along the hose to the recessed nipple on the top side of the valve. If the hose is dangling free then theres the problem and its easily fixed
