Well see what the MKVII brings, I posted a link with the mods for the GTI I suspect the R will get tweaked as well.. Havn't seen anyone do the water kit
I think it is the hardware where the R is lacking
Needs a change to the geometry (improve turn in), brakes are overboosted, IC is far too small/inefficient, needs a water kit for summer and do on.
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
i was just about to ask, does anyone do a water kit? and there you go...
I was wondering, how hard can it be to get a hobbs pressure switch that pips out at 10psi....
easy to do, just the +12V that would need to be sourced and relayed over canbus perhaps?
More opportunites have been lost from indecision, rather than wrong decision....
I still have the water kit I made for my Forester. Haven't looked at the headlight washer system in the R but should be able to tap into easy enough and add a new supply
Talking of MkVII specs - any word on the number of gears?
I never thought I would say this but I could go a 7th (if it's good enough for Porsche...). Surely the engine could pull 2000rpm or less at 110kph, instead of ~2500rpm that mine pulls in 6th?
I assume the manual and DSG are close, if not the same, in terms of ratios.
Looking for:- RS4 B7 Avant.
Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
nooo..
the DSG is faster....
especially if white.
I'd prefer a 5 speed DSG with a taller top gear
The R has enough torque to handle wider ratios
But your fuel economy would be garbage
True.
One of the most annoying things on the golf is the disparity between D and S on the DSG.
D is quite possibly "Docile" instead of "Drive"
"S" is too "stupid" for daily drives.. even for the spirited driver.... 60km/h and I have to hope it gets into third...let alone 4th etc etc....
a middle ground "M" (or for quirkyness sake,we could have it "G" for generic, thus completing the trifecta of D S G) would be nice.... can't be that hard to include a factory fitted button to alter the shift points on the car could it???
