i have a manual... clutch in.. revs won't go over 4,000rpm when at a stand still... won't let you dump it..
nom nom nom
OK, have searched the forum and Google. Maybe my keywords aren't right
My RCD510 used to not autoplay from SD cards and my iPhone
Now it autoplays as soon as I connect the phone via MDI or if I insert an SD card
This isn't the bt autoplay issue (I am aware of that setting and turning it on or off made no diff)
I haven't changed any settings, can't find any that control this and nothing in the manual that I can find
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
My R has now done 5000km I just checked the oil levels and its pretty low. What oils do you guys recommend for a top up?
Candy White Golf R DSG MDI Bluetooth & Bluefin installed!
Any 504.00 but 502.00 will do at a pinch. They are the magic numbers to look/ask for.
Question for DSG experts,
I was reading the Wikipedia entry on DSG today and I noticed that it implies that Sport mode causes the R to stay in 4 wheel drive more than Drive mode does.
"......On 4motion or quattro-equipped vehicles this may be partially offset by the drivetrain maintaining full-time engagement of the rear differential in 'S' mode, so power distribution under loss of front-wheel traction may be marginally improved......"
Does anyone know if this is really the case, or am I just misinterpreting the article?
2012 DSG UG Golf R plus some options. Loving it!
There's apparently a link to a UK VW page which states similar.
Sometimes it's difficult to know what applies to what cars though. The Golf R has the latest version of the Haldex system where it has a pump assisted clutch which also takes into consideration things like the throttle position and was meant to be able to respond so quickly that it would engage the rear diff even before traction has been lost. So if this is really the case, what's the point of leaving the rear diff constantly engaged?
Yep, this has happened to me, although was more like ~2000revs. Wasn't especially thrilled by it as I thought i'd seen the end of this little trait when I got rid of my V8 rough-as-guts Commodore. I really was of the belief that such a thing could only happen with a cable-throttle car, but evidently not. When it happened in my last car i'd just put it in 1st and half let out the clutch to force the revs to die. Works on the Golf too if it starts to really get to you.
Regarding the maximum 4000 revs with clutch in comment, I actually haven't tried revving it that hard with the clutch in yet. Will try it tonight and see if mine does that too. Doesn't sound right to me...
Another question for those of you with manual - have you noticed when you drive off really sedately in first gear, below about 2000 revs it sort of feels like it hesitates? Sort of hard to describe. Only happens initially and only if you're at like 10-20% throttle. If you have a better crack at the accelerator it doesn't happen. Can't tell whether it's a fly by wire thing or more to do with the 4WD system sorting its thing out at low speeds. Anyone know vaguely what i'm experiencing and got a reason?
DBW. The e46 3 series was bad for it as well.
Audi S3. Sold
Golf R. Sold
Citroen DS3 Dsport. Sold
2016 Skoda Octavia RS Wagon.
