Page 405 of 651 FirstFirst ... 305355395403404405406407415455505 ... LastLast
Results 4,041 to 4,050 of 6510
Thread: Golf R Observations and Questions
  1. #4041
    Nov 2010
    Melbourne, VIC
    Quote Originally Posted by Rob_R View Post
    Used the horn for the first time today and was expecting a wimpy noise but was surprised that a small car has a horn with some balls!!
    I use mine all the time to honk cabbies who think the road belongs to their grandmother! Cabbies annoy the **** out of me. Never had problems with them 5 yrs ago!
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
  2. #4042
    Jul 2011
    Burwood, VIC
    unusual, and possibly dumb, question .. but I'll go ahead and ask it anyway
    .. the very sexy, deep, throaty sound that you hear for the first second or so when you start up the R - what the frack is it exactly? ie. precisely what engine components are responsible for this awesome sound??
    never fails to get me excited
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
  3. #4043
    Feb 2010
    South Perth, WA
    Quote Originally Posted by bluefrog View Post
    All the usual components of an internal combustion engine, however on a cold start the RPM's are higher and both exhaust outlets are open, hence the deeper throatier sound (I think this is what you're referring to?)
    I like this sound too, and usually start mine with the garage door closed so I get more of an echo
    WLF127
  4. #4044
    Sep 2011
    Gold Coast, Qld
    Quote Originally Posted by shakespeare View Post
    Both exhaust outlets open? What's the go there?
    Golf R - 77TSI engine transplant, 91ron tune, & a crochet rug on the parcel shelf
  5. #4045
    Feb 2009
    Sydney, Australia
    The Golf R has a "flapper valve" on the exhaust. One of the pipes only opens over a certain rpm/under a circle throttle load, thus allowing the car to have a high level of exhaust flow when needed, but also to be quiet(er) when that flow isn't needed.
  6. #4046
    Jul 2011
    Burwood, VIC
    very interesting and good to know .. thanks guys
  7. #4047
    Sep 2011
    Gold Coast, Qld
    Quote Originally Posted by Corey_R View Post
    Cheers Is this unique to the R or do the GTI and Audi's have it as well?
  8. #4048
    Feb 2009
    Sydney, Australia
    I'm not aware of a A3 / S3 model which has it, and within the Golf range it's unique to the R.
    Many manufacturers use them these days in their performance models though. Allows them to get around the noise regs but still provide a meaty exhaust sound.
  9. #4049
    Sep 2011
    Gold Coast, Qld
    Cheers Corey
  10. #4050
    Sep 2011
    Gold Coast, Qld
    Found this, it relates to the R32 but maybe the the same for the R -
    That's not a vacuum pump, its a vacuum reservoir with a solenoid valve.
    The MK IV Flapper gets its vacuum supply from the engines intake.
    The Flapper is held closed(Quiet) by vacuum, and opens(Loud) when that
    vacuum supply is shut off.
    The vacuum line runs from the intake to the reservoir/valve, then to the Flapper.
    The solenoid valve is electronically controlled by the ECU to shut off the
    vacuum supply to the Flapper when the rpm gets above 3200-3500rpm in
    3rd, 4th, 5th, and 6th gears.
    I would think the MK V operates off of a similar system. Has anyone chased
    down that vacuum line that runs to the Flapper to see where it goes?
    And this, more of the same -
    BTW, this was all discussed some time ago over on the R32 forum on tyresmoke.net.
    One theory proposed there, is that the MkV R32's flapper logic is slightly different than the MkIV, as follows.
    MkIV
    off - flapper open
    idle - flapper closed
    Below 3500 rpms or 45 mph, flapper closed
    Abvove 3500 rpms and 45mph, flapper open
    MkV
    off - flapper open
    idle - flapper open
    Between idle and 3500 rpms + 45 mph, flapper closed
    above 3500 rpms and 45mph, flapper open
    Basically they wanted to give it a little more burble at idle so
    they left the flapper open. The only difference is in ECU logic.
    The operation of the flapper itself is the same. No vacuum, it's open.
    Apply vacuum, it's closed.
    Means flapper mod is the same as well. Clamp line, or pull it off
    and plug it, or interrupt the signal wire from the ECU, and it's open.
