Please use search, or look at the MK6 forum index... cheers.
Why didn't they implement the SMS option on the RCD510 as mentioned in the manual. Would be great.
Less distracting than having messages show on the small iPhone screen !
Also wish it had voice control as described in the manual. Even the wife's little Fiesta has it !
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
Yeah, it would be awesome if you could read SMS messages on the MFI, perhaps restricted to under a certain speed. Can't be any more dangerous than scrolling through the phonebook while driving![]()
Less dangerous than scrolling through 4,000 songs as well
The function is possible as it is in the manual. Clearly disabled for AU ?
With any luck someone will stuble across a VCDS setting that enables it then![]()
The RCD510 and RNS510 support it. I'm pretty sure it's the bluetooth module which determines whether it can be done or not, but the "MY11 Bluetooth" (9ZB) option which they introduced for $550, and is now free, doesn't support it.
Having said that, the iPhone doesn't support rSAP, so I'm not sure that the iPhone supported SMS via bluetooth even for the bluetooth modules that did support that function.... but maybe someone who has one of the old "Premium bluetooth kits" which does support SMS can way in on that..... although, I'm sure it's covered in the correct area of the forums....
http://www.vwwatercooled.org.au/foru...510-31461.html
One thing I've noticed in the R.... with the DSG gearbox, if you manually go down a gear with the brakes on - it snaps down a gear almost instantly. If you manually go down a gear while accelerating, it takes like half a second longer to think about it. If you mash the fast pedal all the way to the switch to make it change down a gear - it's almost instant.
My car: MY18 Arteon
My car #2: MY22 Volvo XC40 Pure Electric
Her car: MY22 Skoda Octavia Limited Edition Wagon
Not seeing this with our DSG on our MY12 R
Manual changes are immediate under braking or acceleration
Also finding the D mode has much better shift points versus our GTI
